Guest Rays the roof Posted April 7, 2011 Share Posted April 7, 2011 Right rubber Vac pipe that connects inlet manifold to brake servo - SORTED! 1 small bleed nut off jap spec caliper. Cheers Ray Link to comment Share on other sites More sharing options...
Jonny5 Posted April 7, 2011 Share Posted April 7, 2011 Hi Ray If its the 'S' pipe that comes directly off the inlet manifold (banjo) to the hardpipe, I've got a spare one you can have.. cheers Jon Link to comment Share on other sites More sharing options...
Guest Rays the roof Posted April 7, 2011 Share Posted April 7, 2011 Brilliant! I'll pop over and collect over the weekend if you are around. Got to be worth a pint! Link to comment Share on other sites More sharing options...
Jonny5 Posted April 7, 2011 Share Posted April 7, 2011 Brilliant! I'll pop over and collect over the weekend if you are around. Got to be worth a pint! No worries you have a pm;) Link to comment Share on other sites More sharing options...
straightsix Posted April 10, 2011 Share Posted April 10, 2011 Still after the bleed nut? (I'm assuming you mean the bleed nipple?) I might have one in the garage - will check in the morning. PM me if you still need this Link to comment Share on other sites More sharing options...
