Help Required!
Guest KernalRob
Guest KernalRob
Hi Guys & Girls
Im currently doing an Open University Engineering degree which involves working on designing a new product or improving an existing one.
The problem I have chosen is the bug bear of cleaning ice off our car windows first thing in a morning. I was wondering if anyone would be willing to answer a couple of questions to help me with my research?
So here they are:
Whats the current method you use clear car windows of ice and why?
Any current problems people have with exisitng products they use? i.e. Scrapers etc...
How long does it usually take you to clear your windows of ice?
Does anyone use any different methods to normal? (i.e. different to scraping, deicer, cover, jug of water etc..)
Has anyone made any modifications to the equipment they currently use to improve it?
Finally
How annoying on a scale of 1-5 is it to have to clear the ice off on cold mornings?
5 = Very Annoying 1 = Not bothered.
Any replies would be greatly received.
Cheers
Rob
I always go for the jug of luke warm water because its the quickest and i'm nearly always running late in the mornings :)
I'd put it at a 4 on the annoying scale. Also, hate using scrapers as they seem to scratch the glass and make visibility worse when there is any glare.
Pour lukewarm water over the windscreen and put the wipers on, very easy and works incredibly well.
Any current problems people have with existing products you use?
No.
30 seconds up to a minute! :eek:
Have you made any modifications to the equipment you currently use to improve it?
During cold days I equip my hands with gloves, which makes them far more effective.
2
Heat on full inside, use scrapper outside. Find it's quick enough for me.
Noticed the scrapper has scratched the windscreen this year, need a differant method next year :(
Less than 2mins
Have used sheet on front of windscreen in the past, ended up giving up due to PITA putting on.
Used warm water which is the best method but now where I live not really possible.
No
5 = Very Annoying :complain:
Depending on how icy, a juke of luke warm water or just an Ice Scraper
Nope
2-3 minutes.
Yes, in a civic which I owned before, I added a remote starter.
I'd leave the heater on full blast hot towards the screen the night before & then in the mornings I would just remote start the car from the comfort of my home. I'd normally start it 4-5 minutes before I left the house. This would melt the ice & also clear the screen, not to mention the engine and car is nice & warm by then to drive off in.
No.
Finally
2.
Just an idea but as a kettle seems to be the most popular ( apart from remote start ) I'd find a way to say modify a kettle so it had special switch to enable it to boil up to around 60 degrees on a timer for instance 7:55 when someone wants to go to work, just an idea hope it helps :)
Guest KernalRob
Excellent answers so far.
Remote start was bordering on an idea i had which was to have heated windows all round the car which runs of a seperate battery that activates when the temperature drops below freezing even without the engine running (i.e. Parked up over night) and charges along side the normal battery when driving.
l33wgn hadnt thought of that one, would eliminate the risk of cracked window screens and if people were running late wouldnt have to worry about waiting for kettle to boil.
Even if people just use scrapers or the same methods as above, still post replies as it may spark a improvement idea i hadnt thought about.
Cheers
Use the car heater and wipers or a scraper depending on how late I am. Any other method just seems to refreeze.
Got a lovely scraper with fur lined glove attached:) As said above, sprays or water tend to refreeze if it's really cold
Scraping 2 mins, heater maybe 4-5 mins
Nope
Finally
Meh 3
Heater if I have time, scrape and heater if I don't.
Hands get too cold. My girlfriend have a scraper with a fur-lined glove but it's pink and I'm a boy so can't use that.
2-3 mins scraping and heater, 3-5 mins heater.
A piece of perspex about 3x8" that seems more effective than a scraper.
No.
1 if I'm in a good mood and expecting it to be icy. 4 if I wake up on the wrong side of the bed and don't expect the car to be icy, maybe a 5 if I'm running late as well.
I use a car port :p
But on a more helpful note, if I have to use one of the cars not under the carport then as per my missus advice I use water straight from the tap. Seems to clear just as quick as warm water.
Get the temperature wrong and I think the screen can crack.
to remove the ice on the windows i normally start the engine and turn on the heat a little bit, get back into my home drink a cup of coffee, (it takes a little bit time,5 to 10 minutes) depending on the weather circumstances, i deffinately give it a 5
good luck with your study,,
I always go and start the car whilst I have a cup of coffee in the morning and let it run with the heaters on a little for 5 minuites, doesn't bother me really so I'd give it a 2 as the only thing that changes is that I have to start the car before I have my coffee.
Remove most of the ice with a scraper, squirt on a little de-icer and then get in the car and put the defrost blower setting on full blast.
Yes, I can never find the scraper I used last during the previous winter.
5 mins
Nope.
No modifications but recently I've been using an A4 size 4mm thick piece of plastic which removes the ice quicker.
3
