Benje1990 Posted April 6, 2011 Share Posted April 6, 2011 Hey guys sorry if this makes me sound very nooby im thinking of decating my TT will i need a Restrictor ring as i already have a elctronic boost controler? my mate who builds time attack skylines with 800HP said i wont but thort i would ask? cheers Quote Link to comment Share on other sites More sharing options...
Josh Posted April 6, 2011 Share Posted April 6, 2011 BPU Quote Link to comment Share on other sites More sharing options...
Benje1990 Posted April 6, 2011 Author Share Posted April 6, 2011 Cheers Josh that makes sence now Quote Link to comment Share on other sites More sharing options...
marc_p Posted April 6, 2011 Share Posted April 6, 2011 Yes you will, a RR will stop you from over boosting, a boost controller can't lower the boost levels, only raise them. If I were you I'd get a 1bar RR as there only a few quid and could save you a fortune by stopping the turbos from failing. Quote Link to comment Share on other sites More sharing options...
Tyson Posted April 6, 2011 Share Posted April 6, 2011 RR are not an exact science so it will take some trial and error to find the right size for the boost level you want to use. Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted April 6, 2011 Share Posted April 6, 2011 Depends if you are UK or J-spec. Quote Link to comment Share on other sites More sharing options...
Benje1990 Posted April 6, 2011 Author Share Posted April 6, 2011 Going to BPU the car as it 70% there already going to Use a 2" ring as I've been told it's good for 1.2bar Cheers guys Quote Link to comment Share on other sites More sharing options...
Tyson Posted April 6, 2011 Share Posted April 6, 2011 Depends if you are UK or J-spec. its a jpsec so he will need one Quote Link to comment Share on other sites More sharing options...
Tyson Posted April 6, 2011 Share Posted April 6, 2011 Going to BPU the car as it 70% there already going to Use a 2" ring as I've been told it's good for 1.2bar Cheers guys I would also get a boost gauge to check for boost spikes. Quote Link to comment Share on other sites More sharing options...
marc_p Posted April 6, 2011 Share Posted April 6, 2011 (edited) Going to BPU the car as it 70% there already going to Use a 2" ring as I've been told it's good for 1.2bar Cheers guys If your using a boost controller, get a 1bar RR and then just raise the boost to 1.2 via the controller, if your using a 1.2 RR than the chances of it overboosting are too large IMO, plus makes the boost controller pointless as you wouldn't want to raise it anymore than 1.2. EDIT: Your 'mate' who builds cars for time attacks sounds like he's a bit of a douche if he thinks it's safe to overboost a car, plus it sounds like he thinks you can actually lower the boost level via a controller, which you can't, you can only raise it. Edited April 6, 2011 by marc_p (see edit history) Quote Link to comment Share on other sites More sharing options...
Benje1990 Posted April 7, 2011 Author Share Posted April 7, 2011 LOL my m8's skyline run's at 2.5Bar so he never uses is controller's to lower the boost, witch is what il have to do after i delete the cats, also as he has a big single he will also have a large waste gate, and i belive the only reason u need a RR is due to the small waste gate's on the twins . as i work for a company with a machine shop il just make a few 2.2" 2.0" 1.8" and see what i get cheers and yea i already have a boost gauge Quote Link to comment Share on other sites More sharing options...
Benje1990 Posted April 7, 2011 Author Share Posted April 7, 2011 his* Quote Link to comment Share on other sites More sharing options...
Josh Posted April 7, 2011 Share Posted April 7, 2011 his* You can go back and edit posts instead of making a new one for corrections Quote Link to comment Share on other sites More sharing options...
