Restrictor ring? / Boost controller?
Benje1990
Hey guys sorry if this makes me sound very nooby ;)
im thinking of decating my TT will i need a Restrictor ring as i already have a elctronic boost controler?
my mate who builds time attack skylines with 800HP said i wont but thort i would ask?
cheers
:D
Yes you will, a RR will stop you from over boosting, a boost controller can't lower the boost levels, only raise them.
If I were you I'd get a 1bar RR as there only a few quid and could save you a fortune by stopping the turbos from failing.
Going to BPU the car as it 70% there already going to
Use a 2" ring as I've been told it's good for 1.2bar
Cheers guys
If your using a boost controller, get a 1bar RR and then just raise the boost to 1.2 via the controller, if your using a 1.2 RR than the chances of it overboosting are too large IMO, plus makes the boost controller pointless as you wouldn't want to raise it anymore than 1.2.
EDIT: Your 'mate' who builds cars for time attacks sounds like he's a bit of a douche if he thinks it's safe to overboost a car, plus it sounds like he thinks you can actually lower the boost level via a controller, which you can't, you can only raise it.
Edited by marc_p (see edit history)
LOL my m8's skyline run's at 2.5Bar so he never uses is controller's to lower the boost, witch is what il have to do after i delete the cats, also as he has a big single he will also have a large waste gate, and i belive the only reason u need a RR is due to the small waste gate's on the twins :).
as i work for a company with a machine shop il just make a few 2.2" 2.0" 1.8" and see what i get :)
cheers :D
and yea i already have a boost gauge :)
