NA diff transfer box
t-one234
hey guys,
took my car round to a mate who is a mechanic to look at why my car has a rattle, turns out it was the boot rubber blocks
he then took it for a drive and said there was a vibration under heavy accelerating in 1st gear and he said it could be the diff transfer box
could this be the case? and if so, how expensive is it?
the car is a 1994 manual non turbo
hey guys,
Hi mate yes.......for a diff you looking at £150.00 and around £50 to fit.can you describe the noise in more detail??? ive had 3 go but talking to the members on here its not a common thing.
on all 3 of mine "clicking" was involved....... to both extremes,ive had one just clicking now and again and ive had the other 2 trying to lock up.if i were you id take your boot lining out along with your back seats (the bottom part just pulls out and the top section uses 2 bolts) you will be able to hear whats going on when you take it for a spin alot better and pin point if its 100% coming from the diff.
thinking back the early signs that one was going was like a small rattle when i hit the gass hard in 1st so i recs your diagnosis may be correct and the diff has gone.
if this is the case and you do drive cars hard i recs it would be a good idea to upgrade to a turbo one,there the same money most of the time but are slightly stronger....dont worry about ratios etc as every one on here said to me they were different....i can assure you theres no difference at all in top end or gears being longer/shorter.
hope this helps
  • 2 weeks later...
