Kilps Posted April 3, 2011 Share Posted April 3, 2011 Specialized P1 2009 Dirt Jump Mountain Bike for sale, on behalf of my brother. Standard Spec Frame: Specialized 100% Cr-Mo, Double-butted HT/Downtube, Externally relieved Headtube, Disc mount, 6mm offset horizontal drop out for 26 inch wheel with single and multispeed hardware (Disc only) Fork: Marzocchi DJ3, 80mm, Cr-Mo steerer, 32mm Cr-Mo stanchions, Magnesium lower, Fixed rate cartridge damping, Coil/mcu with preload adjust, "stiff" spring Chainset: Fuse tubular heat treated Cr-Mo 2 piece with hollow 19mm Cr-Mp spindle Chainrings: CNC cut 6061, 28 Tooth Chainrings, Motostar design Bottom Bracket: Fuse Euro, Alloy cups, 4x cartridge bearing Cassette: Single-speed conversion kit Chain: KMC Z510HX, 1/2 inch x 1/8 inch Pedals: Specialized alloy platform, 9/16 inch Front Brake: Avid BB5, Mechanical disc, Calliper/adapter with 160mm G2 Clean Sweep rotor Rear Brake: Avid BB5, Mechanical disc, Calliper/adapter with 140mm G2 Clean Sweep rotor Brake Levers: Avid FR-5, Alloy, Two-finger, Linear pull Handlebars: Specialized alloy Hi Rise P.Bar, Butted, 31.8mm, 55mm rise, 680mm wide, 8 degree back sweep, 8 degree up Stem: Specialized aggro, 3D forged/CNC, 4-bolt, 35mm length Headset: Tank FX, 1-1/8 inch threadless with hollow bolt Grips: Fuse BMX, Single compound, Closed end, 140mm Rims: Specialized/Alex P.Disc AM, Double wall disc with eyelets, 36 hole Front Hub: Specialized Hi Lo, Forged alloy, Double sealed, Ground race, Nutted with 3/8 inch axle, 36 hole Rear Hub: Specialized Hi Lo, Forged alloy, Double sealed, Ground race, Cassette, Nutted with 3/8 inch axle, 36 hole Spokes: 1.8mm (14g) stainless Front Tyre: Specialized Rhythm Lite Control, 26x2.3 inch, 60TPI, Aramid bead Rear Tyre: Specialized Rhythm Lite Control, 26x2.3 inch, 60TPI, Aramid bead Tubes: Specialized Schrader valve Saddle: Specialized Fuse Lo Pro, 8mm rails, PVC bumpers front and rear Seatpost: Specialized alloy two bolt, No offset, Micro adjust, 30.9mm Seat Binder: CNC Alloy Changes from standard spec - Front brake removed. Not included in sale. - Rear wheel swapped for Halo Combat 26” SS wheel, white, 10mm bolt through hub, still running original tyre. Original wheel not included in sale. - Front tyre swapped for Specialized ‘dirt’ tyre. Original ‘street’ tyre included in sale. This bike is used, therefore has the usual slight scratches you would expect on a bike of this nature, but is in generally good condition. There is slight wear to underside of fork bridge due to tyre rubbing, but this does not affect the running of the bike. He's selling it as he has too many bikes, therefore not interested in PX. Cash on collection only. Will not deliver due to risk of damage. £300. Link to comment Share on other sites More sharing options...
