Supra Gaz Posted April 3, 2011 Share Posted April 3, 2011 Ok, I bought this from jurgen to drop into my silver N'A, since ordering it, life has changed so I no longer have need for it. Currently it is on route over the water somewhere due to arrive on the 11th of april. The engine is from a jzx100 chaser auto with around 90,000 km on it. It comes complete with turbo, loom, internals, ecu. It is all standard. I have pics on my laptop which I will put on later. The price is 1100 gbp, I am open to serious offers near to that figure. Delivery can be arranged through jurgen at extra cost payable to him, oryou can arrange your own, I don't know where the engine lands in the uk yet, as jurgen hasn't been told. So, turn your na into a 2500cc single turbo, quick revving beast! Drop me a call on 07734839387 to discuss SOLD SOLD SOLD Cheers Cheers Link to comment Share on other sites More sharing options...
abtin90 Posted April 3, 2011 Share Posted April 3, 2011 I think j_jza80 was after a 1jz might be worth sending him a pm Link to comment Share on other sites More sharing options...
Supra Gaz Posted April 3, 2011 Author Share Posted April 3, 2011 I have had a chat with him already, cheers though dude Link to comment Share on other sites More sharing options...
j_jza80 Posted April 3, 2011 Share Posted April 3, 2011 I think j_jza80 was after a 1jz might be worth sending him a pm Thanks for keeping me in mind though Link to comment Share on other sites More sharing options...
abtin90 Posted April 4, 2011 Share Posted April 4, 2011 No problem Link to comment Share on other sites More sharing options...
Supra Gaz Posted April 6, 2011 Author Share Posted April 6, 2011 Bump! Link to comment Share on other sites More sharing options...
Guest Andy Bird Posted April 7, 2011 Share Posted April 7, 2011 How hard is the swap? Is the sump located correctly for the swap? Does an na box bolt up? Link to comment Share on other sites More sharing options...
Supra Gaz Posted April 7, 2011 Author Share Posted April 7, 2011 A w58 and R154 will line up ok, you can use the sump from an 2jzge (n/a) which bolts straight on. A chap in australia did it in his garage over a day or so, its supposed to be quite straight forward. Everything is here for the conversion apart from the tt6 clocks you would need. Its a cool conversion with an easy 280bhp and tons of torque even before bpu. Link to comment Share on other sites More sharing options...
pedrosixfour Posted April 7, 2011 Share Posted April 7, 2011 I'm doing this swap at the minute and I've stumbled over a bit of info that shows a way of using your NA clocks. A resistor on the back of the rev counter needs to be bridged or removed and a suitable resistor intalled in it's place to allow the different signal from the turbo engine to be read by the NA clock. I'm going to try the resistor replacement method myself for a couple of different reasons but mainly because I am cheap. There is a small word of warning though, if you simply bypass the resistor using apiece of wire certain parts of the ECU will be unshielded from a possible (but highly unlikely) voltage spike. This is not the case if you replace the resistor. A 52k ohm resistor is needed apparently. Make of that what you will and perhaps heed the warning if you are considering anything other than a stock 1JZ ECU as the controlling influence. Link to comment Share on other sites More sharing options...
Supra Gaz Posted April 7, 2011 Author Share Posted April 7, 2011 Everyone I spoke to used tt6 clocks and they needed no adjustment Link to comment Share on other sites More sharing options...
pedrosixfour Posted April 7, 2011 Share Posted April 7, 2011 Everyone I spoke to used tt6 clocks and they needed no adjustment And they shouldn't. The method I've mentioned seems to be the accepted and cheaper alternative to buying TT clocks and using the NA clocks instead. Link to comment Share on other sites More sharing options...
Little Matt Posted April 7, 2011 Share Posted April 7, 2011 Removing the resistor works fine on putting other engines in NA Supras. Wiring isn't too bad, need to keep hold of the N/A loom though. Would you take £900.00 plus delivery for the engine? I can have it collected if need be. Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted April 7, 2011 Share Posted April 7, 2011 arrives next week Link to comment Share on other sites More sharing options...
Little Matt Posted April 7, 2011 Share Posted April 7, 2011 You got anything else I might be interested in Jurgen? In need of engines and gearboxes. Link to comment Share on other sites More sharing options...
Supra Gaz Posted April 11, 2011 Author Share Posted April 11, 2011 Bump! In the country this week. Link to comment Share on other sites More sharing options...
Swampy442 Posted April 12, 2011 Share Posted April 12, 2011 Have you smashed it on Driftworks? Dont forget the drifting tax lol Link to comment Share on other sites More sharing options...
Supra Gaz Posted April 12, 2011 Author Share Posted April 12, 2011 I forgot about driftworks. Anyway, SOLD! Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted April 18, 2011 Share Posted April 18, 2011 engine is now here in my workshop Link to comment Share on other sites More sharing options...
Supra Gaz Posted April 18, 2011 Author Share Posted April 18, 2011 Cheers jurgen Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted April 18, 2011 Share Posted April 18, 2011 Cheers jurgen let me know when you need it shipped and were to. Link to comment Share on other sites More sharing options...
Supra Gaz Posted April 18, 2011 Author Share Posted April 18, 2011 let me know when you need it shipped and were to. im onto the buyer now, cheers mate Link to comment Share on other sites More sharing options...
ray007 Posted April 18, 2011 Share Posted April 18, 2011 im onto the buyer now, cheers mate I hope the buyer has changed his/her mind by now Link to comment Share on other sites More sharing options...
Supra Gaz Posted April 18, 2011 Author Share Posted April 18, 2011 I hope the buyer has changed his/her mind by now if he messes me and Jurgen around mate im coming straight to you dude! Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted April 18, 2011 Share Posted April 18, 2011 if he messes me and Jurgen around mate im coming straight to you dude! also a guy in germany interested if ray ot first buyer dont take it Link to comment Share on other sites More sharing options...
