Scratches on windscreen...
jonathanc
Weather was pretty nice today so I went out for a wee drive... while the sun reflected off the windscreen I noticed a lot of fine scratches on the windscreen...
Is there a safe method to remove them? They don't seem too deep as only visible if reflected by sunlight...
Have a go with a brillo pad and some sandpaper while you are at it. Cos see thru glass is clearly not the in thing in the west mids :p
:rlol: I guess i had that coming, as i said it was a guess, i just thought that if you can polish out light scratches on paint, and get a mirror finish, then maybe you could polish glass. :tongue:
Seriously though, there's no way to get rid of light scrathes on glass? :p
Yes, replace the screen is the easiest and safest way. if you cant see through it you cant go so quick!
Autowindscreens etc will be around £900 fitted, Toyota are around £300 supplied, get autowindscreens to fit for around £50
Ah missed the link on top... machine polish glass .... :S
Halford sell a windscreen repair kit too i think. It's not too bad I won't notice it unless there's reflection or glare so surface scratches i think.
Might speak to the stealership after all I've just bought the car. Also a lot of tiny specs which I presume was from the teflon coating they applied to the paintwork.
Go all out and get the heated windscreen from whifbitz to replace it! New and practical!:thumbs:
There's heated windscreen for the sup? o.0 nice...
It's not for a Supra tho :p
I would love to buy one but parking space in my new house is very tight. No space to park even on the street lol.
It is for a Supra. He had them made specifically for it.
You can machine polish the scratches out of the glass. There are good pastes that do it. I wouldn't recommend just going at it though, you really need to know what you are doing with these things :)
Yeah, I am bit nervous about using machine to polish glass esp windscreen (don't want to make the car undrivable lol). I will have a chat with my dealer and see what he says. Funny how they avoid you like a plague after handing the money over :)
I have removed scratches from my screen using a polisher and compound before now with no problems, basically the same as polishing paintwork, you can even use fine wet & dry, rather do it myself than trust a dealer/garage any day.
Did you use a machine or by hand?
The link shown earlier in this thread uses a modified bit which you put in a drill (
You drunk again? He said he used a polisher, you even quoted it ;)
well...not yet but getting there matey :p
Don't have a polisher :( ONly a cheap halfrauds orbital polisher thingy not sure if that even works now lol.
Thanks Ricky. I will have a look into this but really hoping stealership would look into replacing the windscreen (fat chance but gotta try!)
