barneybrendan Posted April 2, 2011 Share Posted April 2, 2011 Has anybody ever replaced one .im scratching my head as to how i get at the damn thing. Quote Link to comment Share on other sites More sharing options...
Guest ugp Posted April 2, 2011 Share Posted April 2, 2011 I've got one at work with a duff starter. I took one look and didnt even attempt it, we just bump the thing every morning. If you ever find a way that doesnt involve pulling the motor, please let me know Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted April 2, 2011 Author Share Posted April 2, 2011 not looking good then is it.going to have a go tomorrow if its dry.looks like you need to undo the cat/downpipe. Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted April 2, 2011 Share Posted April 2, 2011 mate just spoke to kerry and he has never done one sorry Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted April 3, 2011 Author Share Posted April 3, 2011 stuff that it can say like it Will have to just bump it.luckily im on a slight hill and i can just be carefull where i park it. Quote Link to comment Share on other sites More sharing options...
Guest ugp Posted April 3, 2011 Share Posted April 3, 2011 I thought you might I bumped the idle up too so it wasn't as easy to stall, because you look a right tw4t at the lights getting out and pushing it! Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted April 4, 2011 Author Share Posted April 4, 2011 i have never stalled it before just have to remember to open the fuel cap before i start it to get fuel.Hope they dont realise the engine is running as i fill up though. Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted November 8, 2011 Author Share Posted November 8, 2011 finally got the starter out not too bad a job realy.,but noticed the exhaust manifold is cracked and its all very sooty around that area.Starter is caked in soot.The van was a bugger to start at time ,would the cracked exhaust manifold cause problems.I am now thinking do i try and remove it or leave it and just do the starter. Quote Link to comment Share on other sites More sharing options...
Guest ugp Posted November 9, 2011 Share Posted November 9, 2011 Come and do mine then, I'm still bumping the thing! Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted November 10, 2011 Author Share Posted November 10, 2011 (edited) mate its easy really i done it on my back with van on axle stands.If you werent so far away i would . 1.once van is jacked up remove drivers wheel and inner arch cover. 2.undo exhaust clamp(the one that joins the system to the pipe going to the cat) 3.undo 2 10mm nuts holding exhaust to the cat.(i couldnt as mine are rounded) 4.from wheel arch remove the bracket that holds the cat 10mm nut and 50 star drive. 5.undo the 4 nuts holding the cat to the turbo 6.remove cat(i had to leave it there but just move it around ) you can now see the starter unclip the thick wirring loom that hides the starter bolts. 7.undo the bolts that hold the support plate and the starter in position (there is a small bracket that needs romoving first to get at the top bolt) 8.undo the 2 wires to the starter 9.hey presto its off a light is also handy to see all the bolts.bolt sizes were 10mm 13mm torque number 50.long extension bars were handy and a 13mm ratchet spanner. Edited November 10, 2011 by barneybrendan (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest heelandsrocky Posted November 22, 2016 Share Posted November 22, 2016 Hi, Braneybrenden I just want to say thanks for your help in the step by step description on how to remove the starter motor, , Im a mechanic ,but I never touch Renaults as a rule, but this one belongs to me. its one if not the worst starter to replace. But that's typical of French cars... once finished, I breathed a sigh of relief.. bi [GRIN][/GRIN] Quote Link to comment Share on other sites More sharing options...
