Supralad Posted April 1, 2011 Share Posted April 1, 2011 The otherday i drove for around 45mins with no problems in the car (obviously unaware if there was a rattle due to the noise) but when i pulled up to fill her up, the car dropped to its usual 800/1000 revs and there was a really loud rattle coming from the bonnet right in front of the driver. Any ideas? Cambelt? Clutch? It doesnt happen if i rev to 1200, only when idle. But i just started her up moments ago and there was no rattle... still want to find out what it was to solve it before it becomes a major problems. Thoughts appriciated guys! Cheers Link to comment Share on other sites More sharing options...
monsween Posted April 1, 2011 Share Posted April 1, 2011 Does it happen in gear or just on idle? Link to comment Share on other sites More sharing options...
Nic Posted April 1, 2011 Share Posted April 1, 2011 there was a really loud rattle coming from the bonnet right in front of the driver. Some suggestions: Turbo heat shield Exhaust heat shield Crank pulley Random loose bolt Link to comment Share on other sites More sharing options...
Supralad Posted April 1, 2011 Author Share Posted April 1, 2011 When Idle, didnt matter if it was in gear or not. Thanks Nic, if i take it to my garage tomorrow, is it hard to look and locate the crank pulley? Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted April 1, 2011 Share Posted April 1, 2011 exhaust heat sheild maybe? Link to comment Share on other sites More sharing options...
Guest wantthatone Posted April 1, 2011 Share Posted April 1, 2011 change driver? Link to comment Share on other sites More sharing options...
Slicknick Posted April 1, 2011 Share Posted April 1, 2011 Could it be something a simple as the bonnet strut not being clicked back into place? If you have looked at the engine since and the noise has gone away you may have clicked it back in without noticing. Just an idea. Link to comment Share on other sites More sharing options...
ManwithSupra Posted April 1, 2011 Share Posted April 1, 2011 I was thinking heat shield of some sort as well. Link to comment Share on other sites More sharing options...
Scooter Posted April 2, 2011 Share Posted April 2, 2011 aux belt or cambelt tensioner are possibles too.......... Link to comment Share on other sites More sharing options...
Konrad Posted April 2, 2011 Share Posted April 2, 2011 I would check heat shield first Link to comment Share on other sites More sharing options...
Attero Posted April 2, 2011 Share Posted April 2, 2011 I have exactly the same thing. I'm going to have a look tomorrow. Unfortunately, as soon as I get out of the car to check, it stops. It's pretty loud and only happens when idle. I'm just going to check around for any loose parts. I recently had the crank pulley, cambelt and tensioner changed and made no difference. Link to comment Share on other sites More sharing options...
Supralad Posted April 2, 2011 Author Share Posted April 2, 2011 I have exactly the same thing. I'm going to have a look tomorrow. Unfortunately, as soon as I get out of the car to check, it stops. It's pretty loud and only happens when idle. I'm just going to check around for any loose parts. I recently had the crank pulley, cambelt and tensioner changed and made no difference. i think it cud be just a rattle on a loose part underneath the car Link to comment Share on other sites More sharing options...
DodgyRog Posted April 2, 2011 Share Posted April 2, 2011 If you think it was underneath the car, check the bracket that supports the Exhaust, it's located between the 1st and 2nd Cat flange and secures too the Engine and Gearbox meeting point. Get under the car and give the exhaust a good strong wiggle at this point, I had this exact problem, took me months to find it because it wasn't visable with the naked eye, as the break was between the 2 Cat flanges Other than that as already mentioned while you are under there, check the heat sheilds arount the Cats, very common problem Link to comment Share on other sites More sharing options...
Attero Posted April 2, 2011 Share Posted April 2, 2011 Had a check today. Pretty much tried to move every component on the car that was reachable by hand without pulling things apart and couldn't find the problem! Link to comment Share on other sites More sharing options...
Supralad Posted April 4, 2011 Author Share Posted April 4, 2011 Im 99% sure its a rattle, had a look under the car and you can see someone moving slightly once the car is warmed up which i assume is causing the noice. Also when i bought the car they said to keep any eye on the exhaust as it comes loose. Will update when im certain, but atleast it aint as bad as i first thought/ Link to comment Share on other sites More sharing options...
Attero Posted April 4, 2011 Share Posted April 4, 2011 Im 99% sure its a rattle, had a look under the car and you can see someone moving slightly once the car is warmed up which i assume is causing the noice. Also when i bought the car they said to keep any eye on the exhaust as it comes loose. Will update when im certain, but atleast it aint as bad as i first thought/ Only happens when it's warmed up right? It only happens for me when it's warmed up and I've taken it for a drive. I might have to get someone to quickly look underneath when I pull up somewhere. Everything on my car is pretty darn tight, so I can't see what could be causing the noise. Link to comment Share on other sites More sharing options...
Supralad Posted April 4, 2011 Author Share Posted April 4, 2011 yea it only happens when the car has been running for about 30mins Seems we have the same rattle, is yours coming from infront of the driver? Link to comment Share on other sites More sharing options...
Attero Posted April 4, 2011 Share Posted April 4, 2011 It sound like it is coming from the front-end, yes. I am pretty sure we do have the same rattle (if it's not exactly the same it might at least be in the same place with a similar part) and it's starting to hack me off a bit. I'd like it if we can both work this one out. My heat shields seem very tight in their position, but is it possible that could come loose when heated (as they would expand I'd assume)? Link to comment Share on other sites More sharing options...
Supralad Posted April 4, 2011 Author Share Posted April 4, 2011 Its been pissing me off for days now. I dont think its going to be a heat shield, I think its a bracket that is holding the exhaust. The only way your really going to know is getting the car on a ramp Link to comment Share on other sites More sharing options...
Attero Posted April 4, 2011 Share Posted April 4, 2011 I put the car on four axle stands, got underneath and moved everything. Everything seemed fine, but I'm going to give it another go. Link to comment Share on other sites More sharing options...
Supralad Posted April 4, 2011 Author Share Posted April 4, 2011 Im guessing you will have to take it for a spin so you get the rattle, otherwise u will never find it? Let me know how u get on Link to comment Share on other sites More sharing options...
Attero Posted April 4, 2011 Share Posted April 4, 2011 Im guessing you will have to take it for a spin so you get the rattle, otherwise u will never find it? Let me know how u get on That's right. By the time I exit the car to find out, the rattle disappears. So I need someone to quickly look underneath to find any unusual movements. If I take it to a garage, they will think I'm stupid as they always do because these things never happen when on their grounds. So to save some embarassment, I'm going to find the damn thing myself. Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted April 4, 2011 Share Posted April 4, 2011 i had the same bracket on the exhaust go on mine and its soooo annoying. i just took mine off Link to comment Share on other sites More sharing options...
Attero Posted April 4, 2011 Share Posted April 4, 2011 i had the same bracket on the exhaust go on mine and its soooo annoying. i just took mine off Is it safe to just take a bracket off? Link to comment Share on other sites More sharing options...
Supralad Posted April 4, 2011 Author Share Posted April 4, 2011 That's right. By the time I exit the car to find out, the rattle disappears. So I need someone to quickly look underneath to find any unusual movements. If I take it to a garage, they will think I'm stupid as they always do because these things never happen when on their grounds. So to save some embarassment, I'm going to find the damn thing myself. Really? Mine stays for ages. Also If its coming from where i think it is, then its a braket that has been put on as extra support, so yea you can take it off or screw tighter. Link to comment Share on other sites More sharing options...
