440 j-spec injectors, coilpacks, plugs and igniter.
HadeS
Hi mate, what injectors you got in at the minute, and have you changed the plugs and gapped them to 0.7 as mine new was 0.8 and had missfire's on boost at 1.2.
I had 440 but they are f00ked now so need to replace them. Plugs ngk iridium, I ment about plugs what goes to the coilpacks.
I have a set of used (in fulll working order) 440 JSpec injectors boxed and ready to go. PM me.
How much?
My stock j-spec injectors will be coming out soon aswell if required
How much? :>
how do you konw they are no good the injectors, i have also fitted 440 in mine and runs perfect once warm but floods it from cold with afr reading at 10.8 and missfires slightly as there is too much fuel being pumped in.
Runs great on boost and seems to work well with them, still running my stock ECU.
