mellonman Posted April 1, 2011 Share Posted April 1, 2011 Fitted my braided fuel line last night, and had to take off the throttle body to get to conections,anyway long story short once all back together went out in it full blast to check for leaks car fine then stopped went in got cleaned up and went back out in it had bad miss fire. would not pick up at all untill 5000 real hesatating as if not firing on all cylinders and afrs going mad. so pulled up and checked if i had desturbed something so had a good look at where i had been working and found that the injector plugs seemed a little loose so unplugged and looked at pins and looked very similar to when the pins on the coil packs fail. so i will be refurbing the conectors this weekend bending them to make a good conection has anyone else heard of this happening ? Quote Link to comment Share on other sites More sharing options...
