madwoody1 Posted March 31, 2011 Share Posted March 31, 2011 hi there does anyone know if the supra has a seperate ecu unit for the crusie control as i have the steering wheel and throttle cable unit and was thinking of making it work it has the wires in the car just wondered what else i need cheers Quote Link to comment Share on other sites More sharing options...
chrispot Posted April 1, 2011 Share Posted April 1, 2011 hi there does anyone know if the supra has a seperate ecu unit for the crusie control as i have the steering wheel and throttle cable unit and was thinking of making it work it has the wires in the car just wondered what else i need cheers yes they have seperate ecu for the cruise control. not sure that about the wiring it may be in the loom already, if so it would be quite easy to fit, check to see if you have a spare plug around the master cylinder, is so check if it fits your cruise actuator. good luck regards chris Quote Link to comment Share on other sites More sharing options...
madwoody1 Posted April 2, 2011 Author Share Posted April 2, 2011 yea has the plug and ive plugged it in and put the steering wheel on now just have to find the ecu now Quote Link to comment Share on other sites More sharing options...
