Plumming in twin wastegates
hodge
Modifed an old MS paint file, see pics.
Single wastegate:
http://www.mkivsupra.net/vbb/attachment.php?attachmentid=129381&d=1301610199
Twin wastegate:
http://www.mkivsupra.net/vbb/attachment.php?attachmentid=129380&d=1301610081
Unless you're referring to Johnny g's twin/twin setup?
Yep, it's for mine!
Would it be as simple as a wastegate per turbo, then T'd to the reference?
Is it really necessary to use a vac reference from both turbos??
Not sure on that, is there a link between the two collector branches or are they standalone manifolds? My thinking is that if they are standalone (as the pics appeared to indicate) it would need a balanced pressure reference from both turbos to ensure complete balance.
In theory it shouldn't be any different, so if it's safe to assume both turbo's are working exactly in balance then only one pressure reference is needed from a turbo.
They are separate manifolds Daryll yes. I only ask this because these have been ran before with only 1 reference from 1 of the intake pipes. It's not a problem run a vac reference to both turbo, the only issue is the pipe on turbo 2 will be very close to the manifolds and I want to avoid this if possible.
