liam1 Posted March 31, 2011 Share Posted March 31, 2011 ive got the dreaded click click click and managed to get a replacement starter motor from keron,how difficult is it to change on a n/a, ive never done any thing like this before ive got plenty of tools and would be doing it on my drive, its booked in to the garage to have it done next week would i be better leaving it to a mechanic. Quote Link to comment Share on other sites More sharing options...
hodge Posted March 31, 2011 Share Posted March 31, 2011 It's a piece of cake Liam. Disconnect hour battery, Unplug the connector or 2, (can't remember if there's 1 or 2). Undo the nut and remove the power cable, there's 2 or 3 bolts that hold it in and it just slides out. Reverse this to refit. Simples. Need any help giz a buzz. Quote Link to comment Share on other sites More sharing options...
liam1 Posted March 31, 2011 Author Share Posted March 31, 2011 It's a piece of cake Liam. Disconnect hour battery, Unplug the connector or 2, (can't remember if there's 1 or 2). Undo the nut and remove the power cable, there's 2 or 3 bolts that hold it in and it just slides out. Reverse this to refit. Simples. Need any help giz a buzz. cheers jon will give it a go at the weekend if i get stuck will give you a ring mate. Quote Link to comment Share on other sites More sharing options...
hodge Posted March 31, 2011 Share Posted March 31, 2011 No sweat. Quote Link to comment Share on other sites More sharing options...
DodgyRog Posted March 31, 2011 Share Posted March 31, 2011 Liam before you change try undoing the main feed nut, on the underside of the starter, easier to get at from underneath and give it a good clean and put it back on tight I had this thread recently and the above sorted it, go to the last post, after reading the first http://www.mkivsupra.net/vbb/showthread.php?241446-Starting-Issue-on-an-Auto-help-and-advice-needed Quote Link to comment Share on other sites More sharing options...
liam1 Posted March 31, 2011 Author Share Posted March 31, 2011 Liam before you change try undoing the main feed nut, on the underside of the starter, easier to get at from underneath and give it a good clean and put it back on tight I had this thread recently and the above sorted it, go to the last post, after reading the first http://www.mkivsupra.net/vbb/showthread.php?241446-Starting-Issue-on-an-Auto-help-and-advice-needed i will mate thanks very much. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 1, 2011 Share Posted April 1, 2011 Removal on a ramp is a 5 minute job, literally, as is refitting. On your back, on the drive can be a PITA. Quote Link to comment Share on other sites More sharing options...
