skippyboyo1 Posted March 31, 2011 Share Posted March 31, 2011 Morning guys,right i have a couple of questions im hoping i can get some help with..... Im currently taking my dash out to be sent for flocking..... dash,door cards,rear speaker surrounds,arm rest etc etc and im currently scratching my head as to what im going to do with the dash panel that starts at the ignition and finishes at the bottom of the handbrake.the finish im wanting to achive with this is a shiny black (like my paintwork,my supra is black) As you all know this is coated in a type of rubber,now i have done my homework and know alot of you guys have managed to remove this with nail varnish and other chemicals and then painted so this is an option i have so thanks for that. Now the questions....... ive heard of powder coating and used this process in the past but can you powder coat plastic or is this just a solution for metal? Is there any other process you can think of i could use to get the effect im looking for other than the 2 ive mentioned (painting/powder coating if that is one)..... ...And as usual you start one job and then decide to do others so here is my other......The dash lights,im looking to upgrade from the standard dull green lighting so id be replacing the clock lighting along with all the heater matrix lighting etc etc.ive had a bad experience with using led's (i put them in my rear number plate lights and they lasted about a month) and as you can imagine i dont want to replace the lights and one go out and be taking the dash apart ever other month. so my last question............ Whats the best way to upgrade my dash lighting with out having to re-wire everything? Ill be puting pictures up soon as this is the first time ive actualy took process pictures of the work. thanks in advance. craig:) Quote Link to comment Share on other sites More sharing options...
DodgyRog Posted March 31, 2011 Share Posted March 31, 2011 The best way to upgrade your dash lighting is to buy them from Heckler, used to be £100 on an exchange basis for your old units I think, do a search for him and look under his threads started Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted March 31, 2011 Author Share Posted March 31, 2011 The best way to upgrade your dash lighting is to buy them from Heckler, used to be £100 on an exchange basis for your old units I think, do a search for him and look under his threads started ok will have a look at this.cheers bud Quote Link to comment Share on other sites More sharing options...
Tee from China Posted March 31, 2011 Share Posted March 31, 2011 IIAC powdercoating is only for metal as the temperature for curing would probably warp plastic. Why not flock in a contrasting colour? Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted March 31, 2011 Author Share Posted March 31, 2011 ah right so powder coatings out of the question then.flocking wont give me the shiny black finish i want. Quote Link to comment Share on other sites More sharing options...
DodgyRog Posted March 31, 2011 Share Posted March 31, 2011 I think a Matt finish looks better on the dash, a gloss finish always looks a bit odd to me but at the end of the day, you have to sit and look at it, so if you like the look of the gloss finish go for it, just make sure you do the prep work well to get a good finish Quote Link to comment Share on other sites More sharing options...
Stevo Posted March 31, 2011 Share Posted March 31, 2011 I was originally going to go for a 'piano black' high gloss finish on mine but ended up opting for a matt black topped with a matt lacquer. No regrets whatsoever on my choice. Quote Link to comment Share on other sites More sharing options...
orrggg Posted March 31, 2011 Share Posted March 31, 2011 Just watch when the sun is shining it will blind u if u got a shiny dash Quote Link to comment Share on other sites More sharing options...
Josh Posted March 31, 2011 Share Posted March 31, 2011 I was originally going to go for a 'piano black' high gloss finish on mine but ended up opting for a matt black topped with a matt lacquer. No regrets whatsoever on my choice. Any pics of this? Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted March 31, 2011 Author Share Posted March 31, 2011 I was originally going to go for a 'piano black' high gloss finish on mine but ended up opting for a matt black topped with a matt lacquer. No regrets whatsoever on my choice. yeah id like to see this too Quote Link to comment Share on other sites More sharing options...
jackso11 Posted March 31, 2011 Share Posted March 31, 2011 you want a satin or matt black with a satin laquer. Paints4u.co.uk is your friend. Or, you can get the high gloss finish you want by spray or dip coating......but then your car will look chav and max power. Quote Link to comment Share on other sites More sharing options...
Paul Posted March 31, 2011 Share Posted March 31, 2011 IPA is ideal for getting the original coating off, acetone based products (nail varnish remover) might cause damage or melt the base plastic. Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted March 31, 2011 Author Share Posted March 31, 2011 IPA is ideal for getting the original coating off, acetone based products (nail varnish remover) might cause damage or melt the base plastic. IPA? where would i get this from buddy? Quote Link to comment Share on other sites More sharing options...
Josh Posted March 31, 2011 Share Posted March 31, 2011 IPA? where would i get this from buddy? The pub.. http://www.thelass.co.uk/images/gkipabadge.jpg Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted March 31, 2011 Author Share Posted March 31, 2011 you want a satin or matt black with a satin laquer. Paints4u.co.uk is your friend. Or, you can get the high gloss finish you want by spray or dip coating......but then your car will look chav and max power. but i love max power............ my next upgrade is some spinning wheel trims from halfords and a cherry bomb exhaust.ha Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted March 31, 2011 Author Share Posted March 31, 2011 The pub.. http://www.thelass.co.uk/images/gkipabadge.jpg thanks for that josh! Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted March 31, 2011 Author Share Posted March 31, 2011 IPA? where would i get this from buddy? Sorted....ebay!!!! Quote Link to comment Share on other sites More sharing options...
Stewart10 Posted March 31, 2011 Share Posted March 31, 2011 Yeah that stuff is awesome it saved me literally hours when I bought some of that!! Quote Link to comment Share on other sites More sharing options...
Stevo Posted April 12, 2011 Share Posted April 12, 2011 Any pics of this? Sorry Josh - just revisited this thread and spotted this. I'll get some pics up in the next few days... Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted April 12, 2011 Author Share Posted April 12, 2011 Sorry Josh - just revisited this thread and spotted this. I'll get some pics up in the next few days... yeah id like to see this too please bud Quote Link to comment Share on other sites More sharing options...
Stevo Posted April 17, 2011 Share Posted April 17, 2011 Here you go guys - sorry it took so long. Not all of the refurbed panels have been fitted yet as I'm still waiting to fit the top 'odometer' panel and the right hand 'ignition' panel - you get the idea though. Its a matt black paint with a matt lacquer over it. Haven't gotten around to doing the clock face but might just stick a metal monkey steel cover over it like the heating controls. Have got a set of Hecklers new PCB's to go in too when I get some time over the easter bank hol. Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted April 17, 2011 Author Share Posted April 17, 2011 Here you go guys - sorry it took so long. Not all of the refurbed panels have been fitted yet as I'm still waiting to fit the top 'odometer' panel and the right hand 'ignition' panel - you get the idea though. Its a matt black paint with a matt lacquer over it. Haven't gotten around to doing the clock face but might just stick a metal monkey steel cover over it like the heating controls. Have got a set of Hecklers new PCB's to go in too when I get some time over the easter bank hol. yup i like! been waiting on these pics Quote Link to comment Share on other sites More sharing options...
