My dyno day
TLicense
Thought I'd let you all know how I got on a couple of days ago, when I finally got to put my car on the rolling road to map and run-in the engine.
The *final* spec of the motor is
K&N intake manifold
Custom intake pipework
Blitz twin turbo's (with 0.54 exhaust housings)
Custom intercooler pipework
HKS sequential dump valve
CW SMIC
Stock intake throttle body
Stock intake manifold
PTFE intake manifold gasket
264/264 camshafts
Titan vernier cam pulleys
Full Ferrea +1mm valve train
Stock head porting
Stock head gasket
Power Enterprise cambelt
Stock oil pump
Stock water pump
Stock crank dampener
Stock crank
Power Enterprise main bearings
Fully balanced rotating and reciprocating assembly
RPS flywheel
Carillo H-beam rods
Power Enterprise crank bearings
CP 86.5mm Pistons
Modified Blitz exhaust manifold
Custom downpipe
Blitz D4 wastegates
Aeroquip boost control lines
Aeroquip oil lines
Tanabe touring medallion exhaust
Stock radiator system
WOTM triple fuel hanger
Twin Walbro fuel pumps
Full aeroquip fuel lines
Aeromotive fuel filter (with dry breaks)
Aeromotive FPR (with dry breaks)
Power house racing fuel rail
Siemens 870cc injectors (cleaned and balanced to within 1cc)
Stock UK injector ballast
Stock charcoal cannister
Syvecs S6GP ECU
LS2 WBO2 sensor
5 bar AEM MAP sensor
0-150 PSIG Fuel pressure sensor
K-type EGT sensor
0-150 PSIA oil pressure sensor
Crank case pressure sensor
Stock inlet air temp sensor
Stock coolant sensor
RPS Street Max clutch
6 speed conversion
Import auto LSD
The results at 1.7 bar of boost were:-
FWHP and torque
RWHP and fuelling
Big thanks to Ryan, once again another job well done in terms of the mapping
I'm told this is a record for CW's SMIC, but I think this, along with the stock intake is probably the biggest restriction now. I could fit the 0.72 exhaust housings I have which would increase the lag (it's no problem for me as I've plenty of head room in terms of revs) and would give more power, (albeit at an inefficient rate) but I think this will keep me plenty busy enough for the meantime.
Cheers,
Be interesting to see the pressure drop across my I/C and compare it with whatever you try in its place. I was talking to Dave Rowe a bit ago about intercoolers and even some huge front mounts he sees have terrible cores and have massive pressure drop across them. I have bought a Trust I/C for the new Skyline and have cut the end tanks off to fit a really nice core, but it's a costly exercise. Glad all the hard work has paid off so handsomely :) Excellent result!
Cheers guys. It's been a bit of a hard slog to get here. I would dread to think how many hours and £££'s have gone into this, so all your kind words are very much appreciated. :)
I don't think I will replace it though Chris. Whilst a good quality FMIC would be less of a restriction, which coupled with the larger area would (if correctly ducted) help to reduce intake temps, personally, for this car I prefer to retain the SMIC and keep the active spoiler functionality and the stock look.
Great build this, Tony. Definitely in for pictures.
I know what you mean here. I've got for the SRD/ETS intercooler now, but I'm going to have the Active Spoiler "locked" down, for the stock look. Great result anways mate. Nice one.
