Glass headlights REDUCED
ray007
hi
REDUCED _ £200 Collected to clear
I have a set of used headlights for sale, used in good codition
only bad point is that one of the platic bits with the hole for the bolt is broken, i have the piece and it just needs to be glued back on
also a minor chip/scratch on the passenger side headlight as in pic
looking for £230 collected - dont really want to post as ive had some broken in the post before
these are now sold
thanks
Well I'm gonna try polishing up my plastic ones next week when the cleaner and polish arrive, if this doesn't work then I'll let you know and maybe sort something out- give me 1st refusal if you get an offer if you would?
Sure, if I get an offer I'll let you know. Keep me posted
Btw: you will probably be able to get them clean, but IMO the glass just looks alot better then the thin layer of plastic :)
  • 3 weeks later...
  • 2 weeks later...
  • 1 month later...
Interested in these mate just concerned with bit that has snapped off. Will they be secure when mounted into the supra?
its one clip broken, when you secure the other two bolts closer to the wing they sit tight..
