mellonman Posted March 29, 2011 Share Posted March 29, 2011 Hi there i had a new fuel raill fitted not long back but it's leaking, i have now bought the correct an6 fitting but dont want no leaks at all so will i need to use a thread sealer if so what one? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 29, 2011 Share Posted March 29, 2011 AN fittings seal on a pair of cone seats, you should NOT use any sort of additional sealant or PTFE tape. If it doesn't seal with modest tightening something is very wrong. Post some decent photos if you like. Quote Link to comment Share on other sites More sharing options...
mellonman Posted March 29, 2011 Author Share Posted March 29, 2011 Thanks for that chris good to know, i was told that the fitting that was fitted would work fine but that has turnt out to be incorrect! i wont waste your time chris with putting up pics as it was a air line fitting that was put on i believe. I feel completly let down by this company problem after problem Quote Link to comment Share on other sites More sharing options...
nevins Posted March 29, 2011 Share Posted March 29, 2011 An airline fitting as in a push connector Quote Link to comment Share on other sites More sharing options...
Dnk Posted March 29, 2011 Share Posted March 29, 2011 Airline fitting on a fuel rail ! Name and shame Quote Link to comment Share on other sites More sharing options...
mellonman Posted March 29, 2011 Author Share Posted March 29, 2011 i was told that the 90 degree air line fitting would do just as good, just didnt look as good, it had the fuel line clipped to it one end and threaded to the fuel rail an adaptor the other side. it did work well for a month then i could smell petrol but could see where, then another 3 months later it stinks of petrol and i can see clearly where its coming from, lucky it was a short run wyhen i see it could of been alot worse. Quote Link to comment Share on other sites More sharing options...
