Chris Wilson Posted March 28, 2011 Share Posted March 28, 2011 It may be of interest to know of the problem of J-Spec front turbine housings cracking around the wastegate port. I have quite a collection now and despite turbo re-conditioners saying they will "weld them up and re-cut the seat" I know from personal experience this is rarely satisfactory. I am actually looking for a few un-cracked housings, so if you want to see what to look for please look at this thread in the Wanted section. http://www.mkivsupra.net/vbb/showthread.php?242504-Wanted-urgently.-Front-turbo-J-Spec-VVti-or-none-VVti-with-NO-CRACKS. Quote Link to comment Share on other sites More sharing options...
Branners Posted March 28, 2011 Share Posted March 28, 2011 Hi Chris, Can the cracking around the wastegate be attributed to anything in particular? ie are all the cracked wastegates from high boost cars, or from cars not serviced properly or just from sheer age and use? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 28, 2011 Author Share Posted March 28, 2011 Just old age an poverty John, it's nearly always the front as that does far more work. RX-7 turbos can look simply horrendous due to the much higher EGT's of a rotary engine, whilst turbo diesel engine turbine housings hardly ever crack due to the much cooler EGT's. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 28, 2011 Share Posted March 28, 2011 I always thought that cracking around the waste gate aperture was pretty common on internally waste gated turbos from petrol engines? regardless of car make. Quote Link to comment Share on other sites More sharing options...
Branners Posted March 28, 2011 Share Posted March 28, 2011 Thanks Chris. So unless they are low mileage turbos then theres a good chance the wastegate is cracked? Must be getting really tricky to find a decent set of secondhand turbos. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 28, 2011 Author Share Posted March 28, 2011 It is getting harder, but given the number of cars being converted away from the stock sequentials there must be some around, somewhere. You can run with a crack and probably never know about it, but they do get worse with time and a re built unit is best done on a good turbine housing core, if possible. Quote Link to comment Share on other sites More sharing options...
Branners Posted March 28, 2011 Share Posted March 28, 2011 I certainly keep my eyes out for a decent set, been down the single turbo route and never again. stock sequentials with the boost turned up for me all the way. Quote Link to comment Share on other sites More sharing options...
Homer Posted March 28, 2011 Share Posted March 28, 2011 It's definetely getting to be a more common issue. I have two sets wrapped up in the shed, both sets turned out to have housing cracks on the 1st turbo in exactly the same spot Chris' pictures show. Quote Link to comment Share on other sites More sharing options...
