Tee from China Posted March 28, 2011 Share Posted March 28, 2011 Sorry if this sounds a little stupid but every time I see a picture of a Supra gearbox it seems that the clutch is already mounted and not on the flywheel (being attached to the engine that is) All my life every clutch I have ever fitted or seen being fitted has been to the flywheel and not the gearbox - so how do you get it all together Supra style? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 28, 2011 Share Posted March 28, 2011 It's because the clutch on the TT models is a pull type assembly with the bearing pulling the release fingers to effect clutch release, rather than pushing them. As such the assembly is built up on the bench and slid onto the nose of the gearbox. The gearbox is then bolted to the engine and the clutch assembly is slid forward until the cluctch cover is located on the flywheel dowels. Then the cover bolts are fitted via the access panels in the bellhousing and evenly torqued up. HTH. Good question, I thought Quote Link to comment Share on other sites More sharing options...
Tee from China Posted March 31, 2011 Author Share Posted March 31, 2011 Thanks for the precise answer Chris and not shooting me down as an ignorant pratt! Quote Link to comment Share on other sites More sharing options...
