Rear arms keep coming loose!
dcarrter21
Both the rear arms keep coming loose on the back of my car! Its getting stupid now! Theres no play in the bushes or joints... Anyideas on a solution?
Get it into a specialist ASAP would be my advice. Not something you want to be taking risks with!
Have they been taken out recently to have the bolts changed, as normally the camber bolt seize's to the metal sleeve on the bush.
So what people normally do is cut the old bolt out but if its not done right they cut the metal sleeve on the bush and on the end of it is little teath to grip the subframe.
If they havent been messed with then the only other problem is if they have been moving alot they might have worn away the teeth due to keep moving again the subframe so they will never stay still again with no teeth, or might have worn your subframe away.
They were on there limit for a while( lots of neg camber) then i loosened them off the other day and got a 4 wheel alighnment done. Made sure the garage done them up tight but since then they just come loose! Is it worth dropping the subframe or should i just remove the arm and have a look?
