neilp9876 Posted March 27, 2011 Share Posted March 27, 2011 I'm doing Bedford Autodrome on 9 May if anyone else fancies it? At Llandow somebdy had a pin camera that was taped to the front of the car, can anyone recommend one thats cheap and fairly easy to use? Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted March 29, 2011 Share Posted March 29, 2011 Jamie p gets some good vids maybe send him a msg? he helped me with a question the other day Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted March 30, 2011 Share Posted March 30, 2011 just get yourself a gopro camera mate Quote Link to comment Share on other sites More sharing options...
sideexitsupra Posted March 30, 2011 Share Posted March 30, 2011 Paul at Whifbitz sells these! Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted March 30, 2011 Share Posted March 30, 2011 I certainly do, here you go http://garagewhifbitz.co.uk/frontpage/go-pro-hd-cameras-now-in-stock/ Quote Link to comment Share on other sites More sharing options...
little num Posted March 30, 2011 Share Posted March 30, 2011 Camera's are the least of your problems if you have booked at bedford, they are so strick with noise limits you get no chance to make it quite. If you go out and say do 3 laps then get black flagged then your going home. So make sure your car is very very quite NO second chance's there. Quote Link to comment Share on other sites More sharing options...
shima60 Posted March 30, 2011 Share Posted March 30, 2011 If you want something really cheap and useful that you won't mind if it breaks get a keychain camera. I use them on my Model helo's and put them on the front of the car works really well. Granted its not as good quality as a go pro but for £10 can't really go wrong. http://cgi.ebay.co.uk/mini-spy-camera-video-recorder-key-chain-car-cam-dv-DVR-/220760075782?pt=UK_Gadgets&hash=item3366536e06 Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 30, 2011 Share Posted March 30, 2011 Go Pro Hero HD or the older none HD one. I found it hard to tell the difference in quality when we had the two working on the same car. To get better quality would apparently cost a LOT more. As for Bedford you need a stock exhaust, or if you are feeling VERY lucky a Tanabe Medallion Touring. I have several superb stock cat back systems but they would need collecting. Have a good and safe day Quote Link to comment Share on other sites More sharing options...
James Posted March 30, 2011 Share Posted March 30, 2011 Another good device is actually the Zoom Q3 HD. It is actually more of a musicians product as it focusses as much (if not more) on sound. It has a high quality dual condenser microphone arrangement which records at 24 bit/96kHz (much higher than CD quality). This is done in conjunction with a full HD video recorder (records up to 1080p HD at 25Hz, though also does 720p at 50Hz). It has a threaded bottom so that it can be mounted onto a stand of sorts for stability. The Go Pro and such may be better for video (I haven't read up on them) but the Zoom is fantastic if you want the best sound quality to be captured to go with your video Quote Link to comment Share on other sites More sharing options...
SteveL Posted March 30, 2011 Share Posted March 30, 2011 Neil, if you can get to Bedford before the trackday or before booking, they will do a sound test to make sure you're ok. Just give them a call to say youre coming down. Quote Link to comment Share on other sites More sharing options...
little num Posted March 30, 2011 Share Posted March 30, 2011 Dont buy the keyfob camera i had 2 and anything past 100mph they went all jumpy as if they couldnt cope with the information. I had 2 on the dash and both did the exact same thing, but did work well under 100mph. Quote Link to comment Share on other sites More sharing options...
shima60 Posted March 30, 2011 Share Posted March 30, 2011 Dont buy the keyfob camera i had 2 and anything past 100mph they went all jumpy as if they couldnt cope with the information. I had 2 on the dash and both did the exact same thing, but did work well under 100mph. Doh not used mine over them speeds haha. As i say i only used mine really for the model helo's. i've put it on the 4x4 to test it but that can't go over 55mph luckily in the car i have a car pc with a webcam hooked up haha. Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted March 30, 2011 Share Posted March 30, 2011 I got a couple of these and I can say that they do very well http://cgi.ebay.co.uk/DVR-Sports-Video-Camera-Spy-Cam-Camera-Mini-DV-Black-UK-/220761644590?pt=UK_AudioTVElectronics_Video_Camcorders&hash=item33666b5e2e heres a clubaristo thread about them http://clubaristo.net/forums/showthread.php?t=23279&highlight=mini+video+camera and a mk4 supra forum link http://www.mkivsupra.net/vbb/showthread.php?211352-Track-day-camera-for-%A317 I used mine at 100 leptons plus at night and I got alot of footage that was acceptable to view for the whole trip from inner city London to Bournemouth and half an hour afterwards when I forgot to switch it off. Quote Link to comment Share on other sites More sharing options...
scotty71 Posted March 30, 2011 Share Posted March 30, 2011 These have been discussed before a while back.... not bad for the price I suppose, and if you trash it so what.... 4:3 image is a bit primative now though. I will try find the thread Another good device is actually the Zoom Q3 HD. It is actually more of a musicians product as it focusses as much (if not more) on sound. It has a high quality dual condenser microphone arrangement which records at 24 bit/96kHz (much higher than CD quality). This is done in conjunction with a full HD video recorder (records up to 1080p HD at 25Hz, though also does 720p at 50Hz). It has a threaded bottom so that it can be mounted onto a stand of sorts for stability. The Go Pro and such may be better for video (I haven't read up on them) but the Zoom is fantastic if you want the best sound quality to be captured to go with your video I have a Zoom H2 audio recorder... I was looking at the Q3 but it only recorded in rubbish VGA...... didnt realise there was a Q3 HD out Zoom are fantastic products and the audio recorders are mint Quote Link to comment Share on other sites More sharing options...
neilp9876 Posted April 2, 2011 Author Share Posted April 2, 2011 Cheers for the replies. I took the car up there when it had a hks silent on it and it failed the noise test. It has a Tanabe on it now so I was confident it would be fine, I'm not as confident anymore. I will take a look at the various cameras, the older gopro ones are quite cheap but it needs a bit of investigating. Quote Link to comment Share on other sites More sharing options...
James Posted April 2, 2011 Share Posted April 2, 2011 These have been discussed before a while back.... not bad for the price I suppose, and if you trash it so what.... 4:3 image is a bit primative now though. I will try find the thread I have a Zoom H2 audio recorder... I was looking at the Q3 but it only recorded in rubbish VGA...... didnt realise there was a Q3 HD out Zoom are fantastic products and the audio recorders are mint Q3 HD is the gospel dude Quote Link to comment Share on other sites More sharing options...
