Aeromotive and Deatschwerks Fuel Pumps
CanisLupus
Was looking around for in tank Fuel Pumps and have seen the usual pumps(Walbro or denso Stock EU Pump) and then i stumbled upon those two:
Deatschwerks 300+
Aeromotive 340 Stealth
Both seem a very good deal especially because both are proven to work with E85 which is important for me. Has anyone some experience with them?
According to the flow rates would one be sufficient for approximately 600-700bhp on 100octane fuel or do i have to get two of them?
You won't see many European race cars running anything other than Bosch pumps. I tend to follow that norm, and with pumps, sensors and car electrics in general, buy Bosch if possible. Not sure if the Bosch pumps are happy with E85 as I have had no dealings with it. I am *FAIRLY* sure they are OK though as some race series now use percentage ethanol based fuels and I am pretty sure they still run 044 pumps.
We run 720bhp on Steve L's Supra with 1 Bosch and no fuel pressure problems, dont know how much further it will go though.
Wow, that's handy to know, thanks : thumbs:
What base pressure and how much boost as the 044 is supposed to flow really well at higher pressures.
Yes, if the pump is OK with ethanol, and the flow at whatever line pressure is suitable.
Thanks you two. If the Bosch can handle E85 it will be the way for me!
Would you run it with a second pump and Swirl pot(hope spelled it right) or is it ok to just drop it in tank for my power figure(600-700)?
Just one pump in the tank unless you are thinking of doing any serious track use.
Thanks! I think several laps over the Nordschleife don't require a Swirl Pot Setup. Yet :D
Ok this one is odd... The 044 is compatible with E85 BUT:
"With E26/E85 or Diesel fuel run-time max. 500 h. For technical reasons the values may vary. Please use within the specified limit values only." Source: Bosch Motorsport.
I'm not really into changing the Fuel Pump every 500h working hours... :(
I wouldn't worry about changing the fuel pump every 500 hours, with 700 BHP you will be rebuilding the engine long before then if it's used at all hard :)
It will take some time till i get to the 700 but want to use the new Pump as soon as possible for BPU to get rid of the Stock J Spec one.
From my calculations i would have to change the pump every year if those 500hours are correct :(
I'll have to give Bosch Motorsport a ring and see what they think the unofficial runtime will be...
