monkey3 Posted March 26, 2011 Share Posted March 26, 2011 They are dare hiro 19" staggered fitment Rears: 19 9.5 jj 265 30 19 Toyo tr1 Fronts: 19 8.5 jj 225 45 19 Toyo tr1 114.6 114.3 pcd [updated as it seems that I was told the wrong PCD (see post #10) ] They came off an RX8 but I believe they should go on a Supra just fine. I don't know what the offset is but from a quick look on google I think they might be 35 at the front and 40 at the rear. If anyone knows that this definitely wont fit the supra then I'll double check all the markings. The tyres on the front are in really good condition, the rears are getting close to the limit (mainly on the inside) and one has a nail in it. I took it to a tyre shop to be repaired (just to get it through the MOT) but they wouldn't as it was too close to the limit. There is a little bit of corrosion on the chrome part of 2 of the wheels and they're also lightly kerbed (nothing to do with me I might add ) click for bigger picture: http://www.blingpimpin.plus.com/s/rims_small.jpg http://www.blingpimpin.plus.com/s/tyres_small.jpg small amount of corrosion: http://www.blingpimpin.plus.com/s/corrosion_small.jpg rear tread (and nail): http://www.blingpimpin.plus.com/s/nail_small.jpg. They are in Kent, not too far from Maidstone. Link to comment Share on other sites More sharing options...
Jimmy James Posted March 26, 2011 Share Posted March 26, 2011 Could you find out how much for shipping to Somerset ? Thanks. Link to comment Share on other sites More sharing options...
monkey3 Posted March 26, 2011 Author Share Posted March 26, 2011 Could you find out how much for shipping to Somerset ? Thanks. I've had a quick look and it will work out about £50 to anywhere in mainland UK for all 4 by TNT for next day (after day of collection of course). Link to comment Share on other sites More sharing options...
JamieP Posted March 26, 2011 Share Posted March 26, 2011 114.6 pcd Supra PCD is 114.3 Link to comment Share on other sites More sharing options...
Jamesy Posted March 26, 2011 Share Posted March 26, 2011 Yep as above wrong pcd for a supra fellas Link to comment Share on other sites More sharing options...
Supra Gaz Posted March 26, 2011 Share Posted March 26, 2011 Rx8's have a 5x114.3 pcd Link to comment Share on other sites More sharing options...
monkey3 Posted March 26, 2011 Author Share Posted March 26, 2011 Supra PCD is 114.3 Thanks Jamie, I was told these would fit the supra hence why I have them, but they never made it on to my car (because of the nail in the tyre). I take it that's .3 of a mm, in which case, would that really make any difference? (just an honest question as I certainly won't sell these as fitting a supra if they don't) Link to comment Share on other sites More sharing options...
monkey3 Posted March 26, 2011 Author Share Posted March 26, 2011 Rx8's have a 5x114.3 pcd Thanks Gaz, Well these certainly came from an RX8 so they definitely fit that (picture on its way). http://www.carlsalter.com/wheel_fitments.html Link to comment Share on other sites More sharing options...
monkey3 Posted March 26, 2011 Author Share Posted March 26, 2011 I've been told that I'm going to fit them to mine in the morning so I'll get back to you with some pictures then... (watch this space... or don't, whatever ) Link to comment Share on other sites More sharing options...
monkey3 Posted March 29, 2011 Author Share Posted March 29, 2011 Right, far too hung over on Sunday to try to fit them to my car but I now have some pictures of the RX8... http://www.blingpimpin.plus.com/s/rx8_side.jpg http://www.blingpimpin.plus.com/s/rx8_snow.jpg http://www.blingpimpin.plus.com/s/rx8_brands.jpg So, just to be clear, these wheels do fit an RX8 and an RX8 does have the same PCD as a Supra. This combined with the fact that none of the major car manufacturers make a car (in fact I haven't found any car) that has a PCD of 114.6 leads me to believe that I was told the wrong PCD and these wheels are in fact 114.3. Therefore I'm going to change the PCD in the first post to reflect this. I will still endeavor to get some pictures of these on my car, probably at weekend. Link to comment Share on other sites More sharing options...
Guest powerslide Posted March 29, 2011 Share Posted March 29, 2011 shipping should be £40 @ directcouriersolutions.co.uk or paisleyfreight.com Link to comment Share on other sites More sharing options...
monkey3 Posted March 29, 2011 Author Share Posted March 29, 2011 shipping should be £40 @ directcouriersolutions.co.uk or paisleyfreight.com I normally use interparcel.com (who in turn use TNT, UPS, Parcel Force, HDNL, etc. whoever is the cheapest). £50 was a rough guess based on 2 packages (2 wheels in each one due to a weight limit) as follows: (Keep in mind the wheels are stacked in the garage at the moment, not packaged ready to go out the door so the weight and size is a guess based on) each package: 30kg, 60cm x 60cm x 50cm break down width 23" (19" wheels + 4 inches of rubber (overkill)) length 23" height 20" (a front and rear wheel in each package (9.5" + 8.5" + 2" for packaging (again overkill)) and 2 wheels can't be far off 30kg at a guess. So with next day with TNT (as stated above) that works out at £41.72 + vat (currently 20%) = £50.06 If anyone wants it much cheaper then I could use HDNL which is £11.90 + vat = £14.28, but I don't like using them as there is no guarantee when you'll get the package, I think they say any time between 7am and 9pm and up to 7 days or something. OR if you want to buy them then you can organize your own courier if you'd prefer, that also works for me. I got these wheels for nothing from a friend of mine who was trying to save me buying 4 new tires for my car (different wheels) to get it through an MOT. I ended up buying 4 new tires anyway (due to the nail in one of his) and rather than having to cart his all the way back to his for him to sell them I said I'd advertise them on the Supra forum as they should go straight on a Supra. I'm really sorry if that came off as a rant but I'm starting to feel like there are more posts in this for sale thread as to how wrong I am and it's starting to look like I'm trying to stitch someone up, which I'm not. If that was not the case and you were just trying to save the buyer / seller some money then I'm sorry and I'll shut up now. Link to comment Share on other sites More sharing options...
shaz2010 Posted March 29, 2011 Share Posted March 29, 2011 just to make sure these dont fit the supra? Link to comment Share on other sites More sharing options...
monkey3 Posted March 29, 2011 Author Share Posted March 29, 2011 And without the hangover... So, I got them on and checked they didn't foul on anything lock to lock... (must be the largest number of pictures for selling a set of wheels ever!!!) click for the bigger picture: The fronts: http://www.blingpimpin.plus.com/s/front_front_small.jpg http://www.blingpimpin.plus.com/s/front_side_small.jpg http://www.blingpimpin.plus.com/s/front_top_small.jpg Front tread: http://www.blingpimpin.plus.com/s/front_tread_small.jpg And the rears: http://www.blingpimpin.plus.com/s/rear_front_small.jpg http://www.blingpimpin.plus.com/s/rear_rear_small.jpg http://www.blingpimpin.plus.com/s/rear_side_small.jpg http://www.blingpimpin.plus.com/s/rear_top_small.jpg And the rear tread: http://www.blingpimpin.plus.com/s/rear_tread_small.jpg Link to comment Share on other sites More sharing options...
monkey3 Posted April 7, 2011 Author Share Posted April 7, 2011 And then they were gone... Link to comment Share on other sites More sharing options...
