bullet_uk Posted March 26, 2011 Share Posted March 26, 2011 Hi All Will Sup TT brake calipers fit an NA if so what are the best ones to get i think i have j-spec ones on at the moment also what be the best disks to get? Thanks Ty Quote Link to comment Share on other sites More sharing options...
Pete Posted March 26, 2011 Share Posted March 26, 2011 The larger TT callipers can be retro fitted (often referred to as UK brakes), but only on 17" standard wheels or if your after market ones will clear them. Smaller TT callipers are the same as the NA callipers. Generally OEM discs are fine with some decent pads (like Chris Wilsons) unless you're doing track days. Don't waste money on grooves and holes etc. [edit] I should also add that upgrading the rears to match is advisable to maintain the correct braking distribution, but many don't bother. Quote Link to comment Share on other sites More sharing options...
nevins Posted March 26, 2011 Share Posted March 26, 2011 Or you can go down the route of fitting lexus brakes which are just as good as uk's but they are all alloy unlike the uks, and alot cheaper to buy. Quote Link to comment Share on other sites More sharing options...
bullet_uk Posted March 26, 2011 Author Share Posted March 26, 2011 thanks pete i want to change all 4 corners i've got 18'' after market wheels on it can i just put any na calipers on or do they have to be what i have on now obviously ill change the pads to suit Quote Link to comment Share on other sites More sharing options...
Dnk Posted March 26, 2011 Share Posted March 26, 2011 Waste of money in my opinion unless your going to use the car on circuits for trackdays etc, give the brakes you have a service, bleed the system and most importantly use decent tyres Standard pads and discs are plenty good enough for rd use Quote Link to comment Share on other sites More sharing options...
Nic Posted March 26, 2011 Share Posted March 26, 2011 thanks pete i want to change all 4 corners i've got 18'' after market wheels on it can i just put any na calipers on or do they have to be what i have on now obviously ill change the pads to suit You will need to make sure your 18" wheels will clear the larger brake calipers. The larger 4pot front calipers are quite a bit wider and there can be clearance problems between the front face of the caliper and the back face of the spokes. The Supra was fitted with 2 brake options, they are both interchangeable on any Supra model. Smaller Brakes Front - Calipers 2pot/Discs 296mm x 32mm Rear - Calipers 1pot/Discs 307mm x 16mm Larger Brakes Front - Calipers 4pot/Discs 323mm x 30mm Rear - Calipers 2pot/Discs 324 x 16mm Quote Link to comment Share on other sites More sharing options...
bullet_uk Posted March 26, 2011 Author Share Posted March 26, 2011 thanks nic your a big help Quote Link to comment Share on other sites More sharing options...
monsween Posted March 26, 2011 Share Posted March 26, 2011 I go with the above and advise changing all of them if you're going down that route. When i got my car i had 6pots on the front and standard j-specs on the back and didn't like it at all. Now got uk's on the rear Quote Link to comment Share on other sites More sharing options...
bullet_uk Posted March 26, 2011 Author Share Posted March 26, 2011 thanks guys just gotta try and get some now ive pm'ed keron see how i get on Quote Link to comment Share on other sites More sharing options...
