eyefi Posted January 10, 2003 Share Posted January 10, 2003 is there a way u can tell if a car has hybrids, other than by the seat of yr pants. cheers. Quote Link to comment Share on other sites More sharing options...
Terminator Posted January 10, 2003 Share Posted January 10, 2003 I think it is very difficult to do without looking inside the housings. I believe Alex was told his car had hyrids, but found out later they were stock. I guess performance may be a bit of a give-a-way. Quote Link to comment Share on other sites More sharing options...
Ian C Posted January 10, 2003 Share Posted January 10, 2003 You have to remove enough tubing to see the turbine, and give them a spin. Hybrids will feel more massive (i.e. harder to spin because they are steel rather than ceramic) than j-speck stock. That's about as much as you can do as a layperson. I doubt you can tell what 'stage' or type of hybrid they are without stripping them down and knowing what you are looking for. I doubt I could tell the difference between UK spec steelies and hybrids either, just by spinning the turbine. So, yes, you can fit them and not tell your insurance company -Ian Quote Link to comment Share on other sites More sharing options...
Neil Sandham Posted January 10, 2003 Share Posted January 10, 2003 Originally posted by Ian C So, yes, you can fit them and not tell your insurance company -Ian or dodgy garage can charge you a fortune saying they have fitted them and really they have done naff all Cheers Neil. Quote Link to comment Share on other sites More sharing options...
Ian C Posted January 10, 2003 Share Posted January 10, 2003 Not that that would occur. Tut for even thinking about it! Next you'll say the injectors were sold-as-uprated as well, and turned out to be 440cc's! -Ian Quote Link to comment Share on other sites More sharing options...
eyefi Posted January 10, 2003 Author Share Posted January 10, 2003 could u tell by "x" boost at "y" rpm ?? Quote Link to comment Share on other sites More sharing options...
eyefi Posted January 10, 2003 Author Share Posted January 10, 2003 where would b a good place to look for evidence of removal? i know it wouldnt b a cert, but it'd b a start. Quote Link to comment Share on other sites More sharing options...
Alex Posted January 10, 2003 Share Posted January 10, 2003 If its a J-spec and full TT boost doesn't arrive till about 4k at the earliest then I would suggest it has hybrids. 3.5 to 3.8k should be ceramics. Though if there are Ignition Timing devices and uprated cams these could throw off these rough figures. And of course bigger injectors. UK spec ones are Lavender in colour I believe. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 10, 2003 Share Posted January 10, 2003 Originally posted by eyefi is there a way u can tell if a car has hybrids, other than by the seat of yr pants. cheers. No, they will need the compressor housings stripping off and the wheel and housing sizes measuring. The last hybrids i had in for a rebuild weren't, IYSWIM :-) Quote Link to comment Share on other sites More sharing options...
Terminator Posted January 10, 2003 Share Posted January 10, 2003 I wonder how may hybrid cars actually have uprated turbo's. That's two I know of:eek: Quote Link to comment Share on other sites More sharing options...
adi Posted January 11, 2003 Share Posted January 11, 2003 mine have cause i fitted them ! Sometimes the hybrids have a plate stamped on them saying the maker etc and thats a giveaway.. turbo technics normally do this. Of course, this is a giveaway to the insurance so im lucky in that they didnt fit one to mine Quote Link to comment Share on other sites More sharing options...
eyefi Posted January 11, 2003 Author Share Posted January 11, 2003 whats involved with getting at the compressor wheel. can this b done on the car. any gaskets etc involved. forgive my ignorance ive never even seen my turbos yet. Quote Link to comment Share on other sites More sharing options...
adi Posted January 11, 2003 Share Posted January 11, 2003 youd need to take the pipework off going to the turbos.. if its anything like the 1JZGTE then its quite a lengthy job. Even then youd need a normal turbo to compare it to. Quote Link to comment Share on other sites More sharing options...
