Supras M.O.T today.
damadom
Got the car back and bad new it failed. The failure was the offside rear brake pipe was corroded and the brake strip light doesnt work, so to say its been sat in a garage for 3 years and under a cover for 1 year it didnt do that bad :)
All i need to do is get the parts and replace them.
If you mean the strip light in the middle above the Toyota badge, as far as I know it doesn't have to work, some Supra came out the factory with dummy ones. You might want to check if the wiring is there, if nothing else just cover it in tape before taking it back for a retest
DisclaimerWell I think I remember reading that on here anyway about the dummiesDisclaimer
uk cars came with them not working as standard, something to do with not being allowed to have LED lights back in 1993 I beleive.......
You remember correct!
If you go back in to the garage that did the test, ask them to prove its wired in! They won't so they can't fail it. Basically they can only fail it if they can see it wired in and still doesn't work. Or just tell them it isn't a brake light its a dummy for a UK car.
