Parry_10 Posted March 24, 2011 Share Posted March 24, 2011 recently ive got an idle problem the idle was higher when the engine was hot than when it was cold- 1100rpm when cold- 1300rpm when hot took off the icv cleaned it up twisted it to its furthest position and put it back together and reset the ecu. (the icv wasnt sticky it was twisting fine and is perfectly clean now) started the car up really low and lumpy idle then when it got upto temperature the idle was perfect- 800rpm Then started it up this morning really low idle 400rpm and was struggling not to stall then I came to a junction and it stalled- when the engine got upto temperature it was now idling just above 1000rpm and not 800rpm like yesterday. I would of thought that since taking the icv off and apart as it has changed what the idle is doing then the icv is the problem and I should replace it but it wasnt sticky and it looked fine after I cleaned it and put it back on.... before I try and find a new icv I wanted to know if there was any other parts that could cause this problem thanks Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 24, 2011 Share Posted March 24, 2011 Clean the bore of the throttle body and the butterfly edges thoroughly, see what happens then. Use petrol or brake cleaner if immersing, cellulose thinners if used carefully and NOT immersing. Quote Link to comment Share on other sites More sharing options...
Parry_10 Posted March 24, 2011 Author Share Posted March 24, 2011 ok cheers chris I guess I will need to remove the throttle body from the engine to be able to clean the throttle body and butterfly edges? Quote Link to comment Share on other sites More sharing options...
jmcc42uk Posted May 29, 2011 Share Posted May 29, 2011 Mine does this too, did you get any resolution to this? Quote Link to comment Share on other sites More sharing options...
Parry_10 Posted May 29, 2011 Author Share Posted May 29, 2011 turned out to be a faulty tps sensor Quote Link to comment Share on other sites More sharing options...
jmcc42uk Posted May 29, 2011 Share Posted May 29, 2011 Thanks mate, will check this Quote Link to comment Share on other sites More sharing options...
