Sticky calipers/pads?
AJI
Does anyone have any experience of pads/calipers sticking? I don't know if that's the right description of the problem but when I brake I'm getting a noise as thought the brake pad is sticking inside the caliper and then jumping out suddenly onto the brake disk.
I still have full brake power just that I don't like the sound of the pads as they suddenly jump out.
From the sound of it does it look as thought something needs oiling?
Cheers for any help,
AJI
I'm no expert on Supra brakes, but here's my thoughts (which could be completely wrong!)...
Most brakes have piston seals designed with a slight "lip" that holds a bit of tension as the piston pushes the pad onto the disc. When you lift off the brakes, it is this lip that pulls the piston back. The brake pad itself is not pulled back (it's not attached to the piston), it just gets brushed off by the disc.
Maybe the pistons are ok and the brake pads are just sticking in their rails until the disc punts them back against the retracted pistons after you've lifted off the brakes?
It might therefore be a case of just cleaning up the caliper and not having to replace the piston seals?
