Window washer pump relay/fuse
Jurgen-Jm-Imports
  • 6 months later...
Right i kno a lot of you would have put a replacment pump on by now. well my sarger continuse's!!! my problem is- the rear washer squrts water,but the front dose not squrt,when lever is twisted to operrate the rear,i can feel pump working,when i pull the lever to opparate
the front,i feel nothing. A freind carry out a meter test(continuity)Whilst he was working at the pump end he got a full reading when rear was opperrated,& just a little blip when fron opperated,:search: Next i removed the stering consul(to get at the lever) only to scratch my head. Well i have come to a holt on this,has anyone had the same symtons as i have,if so what did you do? as i dont kno weather to replace pump(i checked with a spare pump,same probs) or the lever.HELP pls:(
It wont squirt the front washers when you pull it, only wipe. Have you pressent the button on the end?
  • 8 months later...
  • 8 months later...
Guest kopaloadofthis
I love this site car going for mot was going to fit pump washers weren't working on front and I found the magic button too it just seemed to come from no where
