Replacing existing genuine amp with new
SUPRAJ9373
Hello all
I am new to this site and your assitance in this matter would be of great help and much appreciated as i have searched on the net and unable to locate.
I am looking to replace the original factory fitted amp with an aftermarket but need to know what the wires are so i can use the existing wiring loom instead of rewiring everything. There used to be a diagram on the net but not there anymore.
Can anyone help with this? Thanks
Kind regards
Raj
Edited by SUPRAJ9373 (see edit history)
I'd personally recommend you re-wire straight to your head unit (that is if you are using an aftermarket HU), use good quality connectors and amp wires. It would be much better than using the exisiting connection.
Out of interest what amp are you looking to replace the OEM one with?
