jimmy_supra Posted March 22, 2011 Share Posted March 22, 2011 After two years I have finally got around to fitting my Apexi boost controller. I have got the instructions and the wiring has gone ok. Just need some help with connecting the solenoid. Can anyone tell me which pipes to connect to and which ones to block off any pics would be great. Thanks. Quote Link to comment Share on other sites More sharing options...
Supranature Posted March 22, 2011 Share Posted March 22, 2011 Cant be specific, but read this http://www.max-boost.co.uk/max-boost/supra/boosting_the_beast.htm Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted March 23, 2011 Share Posted March 23, 2011 After two years I have finally got around to fitting my Apexi boost controller. I have got the instructions and the wiring has gone ok. Just need some help with connecting the solenoid. Can anyone tell me which pipes to connect to and which ones to block off any pics would be great. Thanks. There's a guide on mkiv.com under technical. Quote Link to comment Share on other sites More sharing options...
neilp9876 Posted April 5, 2011 Share Posted April 5, 2011 Cant be specific, but read this http://www.max-boost.co.uk/max-boost/supra/boosting_the_beast.htm Have you done this mod, if so can you say what the result / difference was before and after? Quote Link to comment Share on other sites More sharing options...
Josh Posted April 5, 2011 Share Posted April 5, 2011 Cant be specific, but read this http://www.max-boost.co.uk/max-boost/supra/boosting_the_beast.htm That'll come in handy when I come to fit mine. Thanks. Quote Link to comment Share on other sites More sharing options...
Supranature Posted April 5, 2011 Share Posted April 5, 2011 Have you done this mod, if so can you say what the result / difference was before and after? Not yet, I am waiting for a mate who tunes Audi Quattros to go through all the info. There must be members who could comment though. Quote Link to comment Share on other sites More sharing options...
mellonman Posted April 6, 2011 Share Posted April 6, 2011 if you have the instuctions it clearly shows you on a drawing of the (jza80) 2jz gte before and after look here http://www.apexi-usa.com/content/pdf6115.pdf page 47 Quote Link to comment Share on other sites More sharing options...
neilp9876 Posted April 6, 2011 Share Posted April 6, 2011 Not yet, I am waiting for a mate who tunes Audi Quattros to go through all the info. There must be members who could comment though. Its the section in the article that describes why NOT to link the pipes that used to go to the EGBV that worries me (AVCR instructions say to do this). The article says that this can restrict the #2 turbo from pre-spooling, which is what I think is going on in my car since... 1. Theres a big dip in power when it transitions from #1 to #2 turbo. 2. Sometimes it even struggles to make the transition 3. When the turbo comes on line, its not smooth but quite powerful, enough to spin the wheels up when damp. If anyone has had the same issues or done the suggestions in the article then it would be interesting to hear about. Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted April 6, 2011 Share Posted April 6, 2011 Just follow this guide, job done. http://www.mkiv.com/techarticles/avc-r/install/index.html Quote Link to comment Share on other sites More sharing options...
neilp9876 Posted April 6, 2011 Share Posted April 6, 2011 Just follow this guide, job done. http://www.mkiv.com/techarticles/avc-r/install/index.html Paul - The guide above doesnt mention disconnecting the EGBV when doing the install (unless I missed it). If mine has been removed then would you say that the Controller has been fitted incorrectly? Quote Link to comment Share on other sites More sharing options...
mellonman Posted April 6, 2011 Share Posted April 6, 2011 Its the section in the article that describes why NOT to link the pipes that used to go to the EGBV that worries me (AVCR instructions say to do this). The article says that this can restrict the #2 turbo from pre-spooling, which is what I think is going on in my car since... 1. Theres a big dip in power when it transitions from #1 to #2 turbo. 2. Sometimes it even struggles to make the transition 3. When the turbo comes on line, its not smooth but quite powerful, enough to spin the wheels up when damp. If anyone has had the same issues or done the suggestions in the article then it would be interesting to hear about. i think you will find thats what happens at bpu when upping boost, a auto supra can wheel spin at 90mph in the wet with kick down, anyway my avcr acts like 0.8 boost first turbo then during transition maybe drops out a little to 0.7 then massive power surge to 1.3 as i have hybrids Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted April 6, 2011 Share Posted April 6, 2011 Paul - The guide above doesnt mention disconnecting the EGBV when doing the install (unless I missed it). If mine has been removed then would you say that the Controller has been fitted incorrectly? Just fit it the way it says in the guide or pop it in to us and we can do it for you no problem. Quote Link to comment Share on other sites More sharing options...
jimmy_supra Posted April 6, 2011 Author Share Posted April 6, 2011 All fitted and working fine the instructions for the unit did the job. I had some of them missing so printed them off the apexi website. Fairly straight forward in the end. Quote Link to comment Share on other sites More sharing options...
mellonman Posted April 6, 2011 Share Posted April 6, 2011 jimmy, just so you know you will alway have to have this unit switched on as when switched off they can cause boost problems being that it stops you making full boost dont know why had a problem with mine not making boost when unit was off so thought turbos was dead but turned out to be the unit i found this out by pluming it all back to factory and giving it a run and made correct boost levels.just a heads up. enjoy your new toy all you have to do now is set it up as you want have fun Quote Link to comment Share on other sites More sharing options...
neilp9876 Posted April 6, 2011 Share Posted April 6, 2011 All fitted and working fine the instructions for the unit did the job. I had some of them missing so printed them off the apexi website. Fairly straight forward in the end. Glad it went well, I'm going to have a go at putting mine back to those instructions. One question - Did you disconnect the pipes going to the EGBV at all on top of the engine or was all that left as standard? Quote Link to comment Share on other sites More sharing options...
neilp9876 Posted May 7, 2011 Share Posted May 7, 2011 I fitted the EGBV valve back onto my car and it feels SO much smoother with no problems transitioning from turbo #1 to #2. Happy days If anyone else fits the AVCR controller I would recommend not removing the actuator. Quote Link to comment Share on other sites More sharing options...
mellonman Posted September 19, 2011 Share Posted September 19, 2011 I fitted the EGBV valve back onto my car and it feels SO much smoother with no problems transitioning from turbo #1 to #2. Happy days If anyone else fits the AVCR controller I would recommend not removing the actuator. with this back in place you get stock boost from first turbo, how have you upped the boost on the first turbo or left it at 0.7? Quote Link to comment Share on other sites More sharing options...
neilp9876 Posted September 19, 2011 Share Posted September 19, 2011 with this back in place you get stock boost from first turbo, how have you upped the boost on the first turbo or left it at 0.7? The boost will simply be what it is, at a guess it will be standard at 0.7 but i'm no expert on how the boost controller works. Its hard to tell but I think the power dropped a little after i put the valve back on but not by much to be honest and I certainly dont miss it, I only really need the power when its WOT. Quote Link to comment Share on other sites More sharing options...
