Whifbiz exhaust general question
Matt _Aero top_
Hi folks
Just a general question to you members who have the whifbitz cat back system fitted to there supras .
On the backbox what type of rubber do you use on the hanger ? I feel mine may look a tad low , not sure whether I can get a smaller rubber dounut type thing or if it's just streched slightly over the years .
Thanks
Matt
Edited by Matt _Aero top_ (see edit history)
I've used two rubber hangers but find after a little while they start perishing - maybe it's the angle my downpipe is at though as I'm no longer TT. I have a 3.5" system and find I'm probably changing the rubbers every 9 months - Don't know if it's the angle or the weight to be honest. I've tried various shapes/sizes of exhaust rubbers but all in the end stretch and perish I have found.
I was looking at cutting a bit more of one of the hangers off so I could get a better angle and get a poly ring put on, but maybe I'll just try and wait it out until I've changed the downpipe and manifold then just get the exhaust tweaked for a better alignment.
I'll have a look . The one I'm using at the minute is one I used on my old dragger , well there was 2 I just picked the best of the pair , I'll try halfords at the weekend .
Call ahead, when I went after I got my new exhaust they didn't have any "rubber rings" or anything like them.
Hi folks
Thanks
Matt
Hi Matt, have you got 2 on the back mount?
I can't upload pictures from my iPhone for some reason but the rubber I'm using looks like a round dounut with two bigger bits on it 180 degrees from each other .
Hope this makes sence , is this the correct type ? iv so I'll pick another one up today
There should be 2 round rings on the back?
