Geometry check / 4 wheel alignment
Guest Sakura
Guest Sakura
There seem to be questions about this on a regular basis, with members trying to find somewhere to do this properly rather than just the usual tracking or front wheel alignment. Good places with member's recommendations seem to be few and far between, and so have lengthy waits for appointments.
This website is recommended by the Lexus Owners Club, and thought it might be helpful to post it here. Wheels in Motion There is a lot of technical information which I found really useful and helped me to understand exactly why it is so important. :)
A handful of KwikFit garages also do computerised 4wheel alignment.
They are not flexible though, so if you want your own angles set, they'll probably refuse to oblidge. They only do the standard manufacturer's settings (which are not too bad anyway)
Give them a ring and see if there is one near you.
Guest chiefvinso
Hyeline in cardiff use a company near to them and all I can say is that 4 wheel alignment rocks, the printout shows toe in, out, camber etc. The car was much better to drive, I would recommend a 4 wheel alignment and although at a tad over £100 it was well worth it.
I took a printout of the 'lance' settings and tried to bribe the KwikFit operator, but he wouldn't budge.
They are not allowed to set by degrees or mm, but by variance compared to the preset factory settings of the model. Booga.
