jackso11 Posted March 20, 2011 Share Posted March 20, 2011 wanted to take my front discs off today, one came straight off when the wheel was removed but the other won't budge. Any tips? Quote Link to comment Share on other sites More sharing options...
Josh Posted March 20, 2011 Share Posted March 20, 2011 Got a rubber hammer? Quote Link to comment Share on other sites More sharing options...
Shane Posted March 20, 2011 Share Posted March 20, 2011 Hang on, isn't there a couple of threaded holes you can wind some bolts in just for this purpose? I have some old discs in the garden, might go and have a look in a mo. Quote Link to comment Share on other sites More sharing options...
jackso11 Posted March 20, 2011 Author Share Posted March 20, 2011 I think there are some threaded holes, is there a tool to wind in there? or just some old bolts? Quote Link to comment Share on other sites More sharing options...
Shane Posted March 20, 2011 Share Posted March 20, 2011 I think there are some threaded holes, is there a tool to wind in there? or just some old bolts? You got it, just old bolts, the discs will fall into your lap and very little effort with no danger of harming them with a hammer, even if it is a rubber one:) Quote Link to comment Share on other sites More sharing options...
straightsix Posted March 20, 2011 Share Posted March 20, 2011 Cut from edge to centre (obviously not as far as the hub) with a hacksaw or grinder - it will relieve the tension Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted March 20, 2011 Share Posted March 20, 2011 Dont cut anything, as above get a couple of generic Toyota 10mm bolts and wind them into the holes in the discs, will pop off with no dramas Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted March 20, 2011 Share Posted March 20, 2011 Dont cut anything, as above get a couple of generic Toyota 10mm bolts and wind them into the holes in the discs, will pop off with no dramas +1 Quote Link to comment Share on other sites More sharing options...
Dnk Posted March 20, 2011 Share Posted March 20, 2011 Cut from edge to centre (obviously not as far as the hub) with a hacksaw or grinder - it will relieve the tension Quote Link to comment Share on other sites More sharing options...
Big Mark Posted March 20, 2011 Share Posted March 20, 2011 Cut from edge to centre (obviously not as far as the hub) with a hacksaw or grinder - it will relieve the tension I'm usually up for attacking anything with a power tool but even I wouldn't try that. [sHOCK][/sHOCK] Quote Link to comment Share on other sites More sharing options...
Suprash Posted March 21, 2011 Share Posted March 21, 2011 I had the same with the Mrs Mr 2, I just gave the back of the disc a few pursuasive hits with my trusted small mallet and off she came Quote Link to comment Share on other sites More sharing options...
jackso11 Posted March 21, 2011 Author Share Posted March 21, 2011 I haven't tried a hammer/mallet, just the handle of a chizel that I had in my hand from opening a tin of paint and it didn't move easily. I will screw in some 10mm bolts tonight and see what happend. Quote Link to comment Share on other sites More sharing options...
Wez Posted March 21, 2011 Share Posted March 21, 2011 Cut from edge to centre (obviously not as far as the hub) with a hacksaw or grinder - it will relieve the tension Quote Link to comment Share on other sites More sharing options...
The-Plethora Posted March 21, 2011 Share Posted March 21, 2011 Dont cut anything, as above get a couple of generic Toyota 10mm bolts and wind them into the holes in the discs, will pop off with no dramas I must say, there was more than a little drama when mine made the huge bang when it finally came free Quote Link to comment Share on other sites More sharing options...
Dnk Posted March 21, 2011 Share Posted March 21, 2011 (edited) Stop fannying around and get a gas cutting torch on them, bit of heat always works for me followed by hitting it with a 4lb sledge hammer or bigger if req PS: try not to cut through the brake lines or anything else you might think is important, oh and if your wearing trainers or slippers watch the hot disc doesnt land on your toes Edited March 21, 2011 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
jackso11 Posted March 21, 2011 Author Share Posted March 21, 2011 Ok, so I have been pounding it as hard as a can with full 180 Degree swings of a long handle sledge hammer. Its not come of yet and it looks very bent. I will hit is straight again when I get it off and it should be fine. Back to the hammering, had a rest because I was too tired to lift the hammer again. Quote Link to comment Share on other sites More sharing options...
Wez Posted March 21, 2011 Share Posted March 21, 2011 Ok, so I have been pounding it as hard as a can with full 180 Degree swings of a long handle sledge hammer. Its not come of yet and it looks very bent. I will hit is straight again when I get it off and it should be fine. You have hit the disc so that it is bent, once off you want to straighten it and put it back on, please tell me I read that wrong Quote Link to comment Share on other sites More sharing options...
merckx Posted March 21, 2011 Share Posted March 21, 2011 How did it go with the 2 bolts screwed into the disc? They should be M8 and not M10. Quote Link to comment Share on other sites More sharing options...
Scott Posted March 21, 2011 Share Posted March 21, 2011 Ok, so I have been pounding it as hard as a can with full 180 Degree swings of a long handle sledge hammer. Its not come of yet and it looks very bent. I will hit is straight again when I get it off and it should be fine. Back to the hammering, had a rest because I was too tired to lift the hammer again. You seriously scare me. You need spoon fed with everything you do, then you don't take any of the advice given during said spoon feeding, then you plan on putting bent discs back onto your car after straightening them up with a hammer? Seriously? For your own safety and for the safety of those around you please just take your car to someone with half a clue about what they are doing. Quote Link to comment Share on other sites More sharing options...
jagman Posted March 21, 2011 Share Posted March 21, 2011 Ok, so I have been pounding it as hard as a can with full 180 Degree swings of a long handle sledge hammer. Its not come of yet and it looks very bent. I will hit is straight again when I get it off and it should be fine. Back to the hammering, had a rest because I was too tired to lift the hammer again. LOL- "move away from the tool box, now" "yes you in the Garage,move away from the tool box" Quote Link to comment Share on other sites More sharing options...
jackso11 Posted March 21, 2011 Author Share Posted March 21, 2011 You seriously scare me. You need spoon fed with everything you do, then you don't take any of the advice given during said spoon feeding, then you plan on putting bent discs back onto your car after straightening them up with a hammer? Seriously? For your own safety and for the safety of those around you please just take your car to someone with half a clue about what they are doing. Er......no, not seriously, it was a joke. You think I seriously hit a brake disk with a sledge hammer until it was bent out of shape.....then plan on straightening it and putting it back on? I asked how to get a stuck disc off, answer = bolts in the threaded holes. There rest of this thread seems like a laugh to me. Blowtorch? angle grinder? surely you picked up on those jokes scott? Quote Link to comment Share on other sites More sharing options...
Paul Posted March 21, 2011 Share Posted March 21, 2011 Kill it with fire !! Quote Link to comment Share on other sites More sharing options...
Purity14 Posted March 21, 2011 Share Posted March 21, 2011 You'll need your alignment looking at now, good job Quote Link to comment Share on other sites More sharing options...
Scott Posted March 22, 2011 Share Posted March 22, 2011 Er......no, not seriously, it was a joke. You think I seriously hit a brake disk with a sledge hammer until it was bent out of shape.....then plan on straightening it and putting it back on? I asked how to get a stuck disc off, answer = bolts in the threaded holes. There rest of this thread seems like a laugh to me. Blowtorch? angle grinder? surely you picked up on those jokes scott? Phhhewwwwwww. I honestly didn't, I wasn't sure just how mental you actually were Is it off now then? I'm surprised you are having so much hassle on the fronts, the rears are much more difficult. Quote Link to comment Share on other sites More sharing options...
Dnk Posted March 22, 2011 Share Posted March 22, 2011 Is it off now then? I'm surprised you are having so much hassle on the fronts, the rears are much more difficult. Not with my method their not Quote Link to comment Share on other sites More sharing options...
