OEM Side Skirts
Calorus
They are getting harder to get hold of these days and as Brendan says above, with the rear spats Pudseys are priced spot on. They go for that sort of money regularly if the are original OEM skirts and not fibreglass copies
Good luck in your hunt, if you are trying to get cheaper ones, but expect them to have some fairly heavy damage and in need of repairs
I'm not entirely sure I mind copies, should you know where I might find any, I just want the car to look a bit less garish - so am hunting for the simplest stock parts.
Ideally, am after these:
Or at a push these:
I got some genuine ones as im after the standard pod and trim bits. Theres a slight crack under one from when it was on a lift but its hard to see unless you get down and look. Ive got some pics if you need some. Im after 350 posted.
