Guest hoylegj Posted March 19, 2011 Share Posted March 19, 2011 Hi, I've been trying to find the ICA on my 2000 twin turbo. Evey manual and picture on this site so far does not match my build. Its a standard engine, Straight from the factory in 2000 and a uk build. This is mad, does anyone know. Any help would be gratfully recieved. Thanks Geoff. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted March 19, 2011 Share Posted March 19, 2011 Should be on the end of the of the inlet manifold nearest the bulkhead. Black round cap on it and a grey plug Quote Link to comment Share on other sites More sharing options...
Guest hoylegj Posted March 20, 2011 Share Posted March 20, 2011 Hi, thats what the pics I've seen show, but its not there and can't see any round type valve :-( , really daft, begining to think it hasn't got one, but the idle running is just like is sticking. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted March 20, 2011 Share Posted March 20, 2011 It cant not be there or the car wouldnt run. Assuming your car has a stock manifold. Stick some pictures up Quote Link to comment Share on other sites More sharing options...
Nic Posted March 20, 2011 Share Posted March 20, 2011 Does the 2JZ-GTE VVTi with electronic throttle control have an ICV? Quote Link to comment Share on other sites More sharing options...
johnny g Posted March 20, 2011 Share Posted March 20, 2011 True DBW doesn't have IAC. I know the idle mechanism on the VVTi's is different to the pre-VVTi's with the cable throttle. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted March 20, 2011 Share Posted March 20, 2011 Not what Toyodiy thinks.... Quote Link to comment Share on other sites More sharing options...
Scooter Posted March 20, 2011 Share Posted March 20, 2011 (edited) Some possible helpful links? http://www.mkivsupra.net/vbb/showthread.php?45814-tps-Problem-Case-Notes&highlight=throttle http://www.mkivsupra.net/vbb/showthread.php?42211-Yet-Another-Vvti-Tps-Problem/page2&highlight=throttle http://www.mkivsupra.net/vbb/showthread.php?52248-TPS-problem-solved&highlight=tps or perhaps not re-reading the original post! Edited March 20, 2011 by Scooter (see edit history) Quote Link to comment Share on other sites More sharing options...
johnny g Posted March 20, 2011 Share Posted March 20, 2011 Not what Toyodiy thinks.... Aye, the DBW on the 2JZ isn't true DBW, it's still throttle linked, just with the ECU tied into it. Quote Link to comment Share on other sites More sharing options...
Guest hoylegj Posted July 18, 2011 Share Posted July 18, 2011 thanks eveyone for your help, cleaned just about every valve I can find, and its a little better, still can't work out whats setting the idel speed and yes it is a VVTi engine, doesn't appear to have the ICA at all , thanks again, added a few pics of the cars getting it respary after a lorry hit the rear end big time :-) thanks for you help Quote Link to comment Share on other sites More sharing options...
Ian C Posted July 18, 2011 Share Posted July 18, 2011 (edited) The VVTi doesn't have an idle control valve, I would presume it's all done off the throttle butterfly, as stated already. See attached pic Toyodiy must have mixed up their "thlottles" hah Edited July 18, 2011 by Ian C My smileys aren't working :( (see edit history) Quote Link to comment Share on other sites More sharing options...
Ian C Posted July 18, 2011 Share Posted July 18, 2011 Which brings us to the question - what's actually wrong with your idle, what are you trying to change/fix Is it too low, too high, varies a lot? Quote Link to comment Share on other sites More sharing options...
EMPEROR Posted July 18, 2011 Share Posted July 18, 2011 Not what Toyodiy thinks.... Mate, you are on page 1, which is ('9305-'9709)... this is not VVTi, click Next illustration ('9709- ), there is no Idle Control Valve there... Quote Link to comment Share on other sites More sharing options...
Guest hoylegj Posted July 18, 2011 Share Posted July 18, 2011 Yes Ian, that's the lump, idle is to low drops to about 500 when in gear and 600 ish out of gear, just don't want to start moving bits without some idea whats what Quote Link to comment Share on other sites More sharing options...
EMPEROR Posted July 18, 2011 Share Posted July 18, 2011 I would just recommend you to remove the hose that goes to the TB and use some degreaser spray... If the ICV function is played by the throttle butterfly, then this seems to be the problem. Quote Link to comment Share on other sites More sharing options...
JODY T Posted July 18, 2011 Share Posted July 18, 2011 There is s little Allen key pin thingy near the throttle body that holds the throttle spring mech out ( the bit with the cable in it..) Just undo it and move to get desired idle.. Tighten and hey presto.. Quote Link to comment Share on other sites More sharing options...
