JohnHandy Posted March 19, 2011 Share Posted March 19, 2011 Cruse control full kit. Includes: Wheel with stork airbag ect ECU Actuator All bolts Edit: need this gone.... Price drop £100 plus post, picture below. Link to comment Share on other sites More sharing options...
dive_popo Posted March 19, 2011 Share Posted March 19, 2011 I guess that you wont split... i need the ecu Link to comment Share on other sites More sharing options...
Scott Posted March 19, 2011 Share Posted March 19, 2011 I would love this but can only imagine it behing a huge pain to retro fit. Link to comment Share on other sites More sharing options...
Swampy442 Posted March 19, 2011 Share Posted March 19, 2011 Ill bet its not easy, must need the loom as well? What wheel is that, stock Supra? Link to comment Share on other sites More sharing options...
JohnHandy Posted March 19, 2011 Author Share Posted March 19, 2011 Some cars have the plugs ready to go took me 10mins to remove! So fitting should be easy. J Link to comment Share on other sites More sharing options...
Scott Posted March 19, 2011 Share Posted March 19, 2011 Some cars have the plugs ready to go took me 10mins to remove! So fitting should be easy. J Got any information on the loom plugs I should be looking for? If I can fit this easily enough I would be interested Link to comment Share on other sites More sharing options...
JohnHandy Posted March 19, 2011 Author Share Posted March 19, 2011 Ecu is currently being sold look further down or use the search button bud. I like to sell as a whole but if I get interest in all pars then I will split. J Link to comment Share on other sites More sharing options...
JohnHandy Posted March 19, 2011 Author Share Posted March 19, 2011 Got any information on the loom plugs I should be looking for? If I can fit this easily enough I would be interested Grey plug top left in the engine bay just above driver side shock. Green plug under dash at knee level for ecu. Edit: you'll need to take the bottom panel off and the air pipe (2 bolts) to see this (your left knee) J Link to comment Share on other sites More sharing options...
Scott Posted March 19, 2011 Share Posted March 19, 2011 Grey plug top left in the engine bay just above driver side shock. Green plug under dash at knee level for ecu. Thanks. Will have a look and get back to you. What sort of figure are you looking for? Cheers Link to comment Share on other sites More sharing options...
JohnHandy Posted March 19, 2011 Author Share Posted March 19, 2011 Thanks. Will have a look and get back to you. What sort of figure are you looking for? Cheers See above edit on under dash location. I'd like to see £ Edit:(Price drop and added to the first post) plus post mate. A full kit is verry rare. If it dossent sell I'll keep it and put it back to stock if I ever sell her. J Link to comment Share on other sites More sharing options...
JohnHandy Posted March 19, 2011 Author Share Posted March 19, 2011 Ill bet its not easy, must need the loom as well? What wheel is that, stock Supra? Yes all stock sup mate. J Link to comment Share on other sites More sharing options...
Swampy442 Posted March 19, 2011 Share Posted March 19, 2011 Also, you know you can remove the cruise stalk from the wheel easy peasy? Link to comment Share on other sites More sharing options...
JohnHandy Posted March 19, 2011 Author Share Posted March 19, 2011 Also, you know you can remove the cruise stalk from the wheel easy peasy? Yes mate but i just fitted this bad boy so dont really need the wheel mate..... Link to comment Share on other sites More sharing options...
David P Posted March 20, 2011 Share Posted March 20, 2011 Cruse control full kit. Includes: Wheel with stork airbag ect ECU Actuator All bolts Sensible offers please, picture below. http://www.mkivsupra.net/vbb/attachment.php?attachmentid=128597&d=1300570755 Please note that the cruise circuits includes a 4 pin brake light switch and a column loom with more connections in the clock spring whirlygoround. I guess that you wont split... i need the ecu I have both a J spec and U.K. spec ECU, the J spec version is limited to around 68mph? U.K. spec is unlimited. p.m. if interested. Link to comment Share on other sites More sharing options...
JohnHandy Posted March 20, 2011 Author Share Posted March 20, 2011 Please note that the cruise circuits includes a 4 pin brake light switch and a column loom with more connections in the clock spring whirlygoround. Perhaps you would care to elaborate a bit more concisely?? As far as I have been informed some cars have the parts required and loom ready to plug in? I have both a J spec and U.K. spec ECU, the J spec version is limited to around 68mph? U.K. spec is unlimited. You have to re-rout the speed signal so the cruse gets the original sensor output pre dsc that way it will work at 40mph on j spec. p.m. if interested. Start your own for sale thread instead of trying to sell on mine please! J Link to comment Share on other sites More sharing options...
David P Posted March 20, 2011 Share Posted March 20, 2011 Yes, you can be lucky and have the correct looms, even if the car has never had cruise. But the 4 pin brake light switch was only fitted to cars with the cruise option. Link to comment Share on other sites More sharing options...
David P Posted March 20, 2011 Share Posted March 20, 2011 You obviously don't want to split it, and I requested pm to not disturb your thread. Yes thank you, I know every little quirk of retrofitting cruise. Link to comment Share on other sites More sharing options...
JohnHandy Posted March 20, 2011 Author Share Posted March 20, 2011 Yes, you can be lucky and have the correct looms, even if the car has never had cruise. But the 4 pin brake light switch was only fitted to cars with the cruise option. 4 pin switch should be cheap to pick up from mr T then! Now please stop posting on my for sale thread if your not going to buy. Thanks J Link to comment Share on other sites More sharing options...
JohnHandy Posted March 20, 2011 Author Share Posted March 20, 2011 You obviously don't want to split it, and I requested pm to not disturb your thread. Yes thank you, I know every little quirk of retrofitting cruise. See above I said I would split if I got interest in all parts. J Link to comment Share on other sites More sharing options...
JohnHandy Posted March 31, 2011 Author Share Posted March 31, 2011 BTT need this sold price doped. Link to comment Share on other sites More sharing options...
