Local PistonHeads dyno day
TTRickeh
Went along to this at a place called Wallace Performance and put the Supra on. Quite a few nice cars and I was the only Supra on the dyno. Some pics for you guys
Vid:
My spec is double decat but stock exhaust, everything else stock, and i'm running stock boost.
They had to put a couple of people on my boot because my tyres were spinning having been stored for about 5 months and only driven slowly 1-2 miles to the RR. I made 306bhp fly (276.4 rwhp) and 320lbft which works out at an estimated 10.8% drivetrain loss which is on the lower side I think.
Graphs:
Something up with the boost tailing off though, right? and it's a little rich at the top? I'm going to have to go boost leak and sticky actuator hunting I think.
10% is low, use 15% and the power seems blob on, anyway sod the dyno, get some better pics up with the kick ass wheels on, gotta be one of my all time fave Supra wheels there.
Not a guru on stock boost levels but holding 10 PSI is normal boost levels? Is it not normal to get peaks on the stock setup around the changover?
Not quite sure J I was struggling to find another stock twins graph with boost and AFR's in it to compare. Yeah still loving the wheels :) Someone else got a good side on pic on the PH forum i'll go see if I can steal it and upload it here. Need to get my finger out and get rid of the stupid adhesive tape that held the spats on too. Did yours have that when you took them off?
It was only the wheels & tyres that hadn't been used for months btw, the car has been used plenty on the stock wheels.
I'm no expert on stock boost, but if it's normal to get small spikes at changeover (as that is what you are seeing, the graph may exagerrate the effect
due to it's scale but in effect you could be seeing at most 1 PSI over stock levels, not a great spike at all).
Yes, just get some cleaner and use your thumb nail to remove the adhesive
Yes get some side on pics up :D
I love the TVR interior. Just as wacky as the rest of the car! The darker coloured Tuscan that was there had a more purple look to it. In typical TVR fashion it developed a fault code stopping the RPM being detected and needed a radiator top-up too.
I've been going at it with AutoGlym intensive tar remover and it's pretty stubborn! Got one side almost done, cannot be arsed with the other side yet!
It was the dyno operator that pointed out the boost thing to me, it started to make sense as my boost guage needle has become wobbly on the 2nd turbo whereas before it just hit the max boost of the turbo and stayed there. This coincided with my removing my boost controller and re-tapping the boost guage into a different source, he asked if I was on the stock actuator too, so adding all the things up and the graph I assumed he was onto something. I thought maybe the guage needle had become a little erratic because of the different source i'd used. I'll have a wee look into it anyway.
I put a hose clamp on the hose coming off the PAS into the inlet mani as it could be pulled off with almost no force, and I covered the wastegate actuator rod beside the 1st turbo in WD40 and moved it back and forth. Boost guage shows boost staying steady now and not oscilating around +-0.1bar either side of whatever the boost actually was like it was before. I think it was the actuator at fault as with the boost controller I had you block the end of it off so it wouldn't have been moving for about 2-3 years so I think it was sticking.
i was there too but didn't have my car on the dyno, it's allready been done a while ago. was a good day, here's the figures of the cars that showed up-
1. slipstream 1985 - noble m12 - 292 bhp279 lbft
2. allandwf - Tuscan Mk1 - 319 bhp, 270 lbft
3. martinj46 - R53 Cooper S - 180 bhp
4. RyanK - R56 Cooper S - 218 bhp
5. J80BUR - 2002 Civic Type R
6. More Steam - Tuscan Mk1
7. MarkRSi - MR2 Roadster
8. John - TR7 V8
9. Ali - Z4MC
10. Dave(D7PNY) - Westfield SeiW - 165 bhp
11. swaltho - Monaro 6.0 VXR
12. Rickeh - Supra TT6 - 305 bhp, 320 lbft
13. OlleyJP - Mini Cooper S R53 GP - 220 bhp
14. Matty-290782 - Scooby sti - 260 bhp 260.3 lbft
15. oedo - 350Z - 260 bhp, 250 lbft
and a few photos from a guy i know who popped past.
Edited by marcAB10 (see edit history)
  • 2 months later...
Went to another dyno day at the same place today. 7c ambient temperature warmer than last time and got 352.4 bhp and 381 lbft which is +47bhp fly and +61 lbft more than last time. Boost just over 16psi peak and 14psi until 6500rpm. Injector duty was about 91% at 6500rpm on stock J-Specs which may be decent information to someone.
Changes to car were Nur Spec S backbox, cheapo eBay ball and spring mechanical boost controller to up boost to a peak of 1.2bar, wiggled No.2 downpipe actuator rod (although I am still convinced it's not 100% free moving), and put a clip on a hose that was a little loose.
Got 324bhp at the wheels though, which works out at 8.7% transmission loss which is even lower than last time. A mate got 13.4% losses in his 350Z. So I think my fly bhp is a bit shy again, a 15% loss would give me 372bhp.
I'll upload a video of some of the cars on the dyno soon for anyone that is interested.
Nice one mate, glad the Backbox is working out for you.. :)
Yeah it fits the bill nicely! Keeps the stock Y-Pipes for silencing and is nice and free flowing as a backbox and I still don't need a restrictor ring. Seems to hang a smidge lower than my Nur Spec RX though.
Vid of some of the cars on the day :)
