David P Posted March 19, 2011 Share Posted March 19, 2011 (edited) I tapped 'Supercharged Supra' into Google images and there is a couple of pics of a 2JZA80-GTZE, they are BMP files and I can't convert them to JPG. This may be of interest to some, so if anyone could import them........... Edited March 19, 2011 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
Wez Posted March 19, 2011 Share Posted March 19, 2011 You should be able to open them in mspaint and goto save-as Quote Link to comment Share on other sites More sharing options...
David P Posted March 19, 2011 Author Share Posted March 19, 2011 (edited) I don't have m.s. paint, or any other program that converts from BMP to JPG, but if no-one can be arsed, so be it. I am quite content with my 2JZA80-GZE, yet I misguidedly assumed that there would be interest in a 2JZA80-GTZE, (big single turbocharged and supercharged) (twincharged) Supra. Maybe it's too prototypical, or not many understand the engine codes. Edited March 19, 2011 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
bignum Posted March 19, 2011 Share Posted March 19, 2011 Maybe you have to much time on your hands:) Quote Link to comment Share on other sites More sharing options...
Scott Posted March 19, 2011 Share Posted March 19, 2011 Can you not post up the link to the images? Quote Link to comment Share on other sites More sharing options...
bignum Posted March 19, 2011 Share Posted March 19, 2011 Can you not post up the link to the images? Nah, he can`t be arsed? Quote Link to comment Share on other sites More sharing options...
dude Posted March 19, 2011 Share Posted March 19, 2011 Adam is doing this to his single (Jagman) Quote Link to comment Share on other sites More sharing options...
David P Posted March 19, 2011 Author Share Posted March 19, 2011 Yes I know, and interested to learn more about twin charging a Supra. Here is the page, but not sure it will link. http://www.google.co.uk/images?hl=en&source=hp&biw=1276&bih=604&q=Supercharged+Supra&btnG=Search+Images&gbv=2&aq=f&aqi=g1&aql=&oq= Quote Link to comment Share on other sites More sharing options...
Scott Posted March 19, 2011 Share Posted March 19, 2011 http://www.mkivsupra.net/vbb/showthread.php?97751-2JZ-GTE-600hp-Rotrex-C38-centrifugal-supercharger Is that the one? Quote Link to comment Share on other sites More sharing options...
David P Posted March 19, 2011 Author Share Posted March 19, 2011 (edited) It did work I thought the pics would be random. 1 and 15 are the twincharged 2JZA80-GTZE, but it is not with the 1G-GZE charger, but number 4 is a 2JZA80-GE with the 1GZE charger which is the one I think easiest to fit to a 2JZA80GTE. I hope that makes sense? Edited March 20, 2011 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
David P Posted March 19, 2011 Author Share Posted March 19, 2011 http://www.mkivsupra.net/vbb/showthread.php?97751-2JZ-GTE-600hp-Rotrex-C38-centrifugal-supercharger Is that the one? Yes, that's what I have been looking for, I was curious to learn what charger it was, I will go and study the thread. Thank you maybe your not such a --@- after all. I have been looking into the fit of the 1G-GZE supercharger onto the 2JZA80-GTE engine. Not that I am planning to do it, I am still busy with my 2JZA80-GZE project, but I just love these scrapyard challenges. Quote Link to comment Share on other sites More sharing options...
David P Posted March 19, 2011 Author Share Posted March 19, 2011 (edited) The thread fizzled out! There are some pics somewhere of it installed in a Supra, I will look there. Here is a pic of a 1G-GZE supercharged engine and pic 4 off that Google page link, an N/A engine with the 1G-GZE supercharger. (It's in there somewhere?) One of these would fit just as sweetly onto a T.T. or single set up. Edited March 20, 2011 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
David P Posted March 20, 2011 Author Share Posted March 20, 2011 (edited) Adam is doing this to his single (Jagman) Adam, stop hiding your proto "Z" under a bushel and post a build thread. Edited March 20, 2011 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
dude Posted March 20, 2011 Share Posted March 20, 2011 Adam, stop hiding your proto "Z" under a bushel and post a build thread. He cant, we are going to build it (to Adams design) Quote Link to comment Share on other sites More sharing options...
jagman Posted March 20, 2011 Share Posted March 20, 2011 Adam, stop hiding your proto "Z" under a bushel and post a build thread. Its simply that you cant do D until A B and C are in place , before 2 air providers , 2 coolers ,and 2 bovs , before high boost cooling improvements,oil and water , and gearbox improvements , anti det measures , it all has to compensate Charger wise I have a nice small twin screw , that will fit nicely , large size of charger is not necessary as its primary function is to provide air to spool a large turbo ...its always the turbo that will provide the large power and air delivery . Every aspect, has not been done before ,so its not a simple bolt on ,ie , water pump will have a reduced pulley , for example, no one makes these , so Paul W has been asked to get one made ,it takes time... twin external thermostats, require pipe fabrication , it takes time ,, no one has run twin coolers , fmic and CC , let alone twin oil coolers staged with rpm control There are other aspects such as pre compressor water meth with again little data around so , as things start to take shape and data gathered . pics of install can be done and bit by bit some explanation for the reasoning for each modification . There is a reason for each and every piece to be fitted , mostly detonation control ,but some for air control to stop comp stall for example Quote Link to comment Share on other sites More sharing options...
David P Posted March 20, 2011 Author Share Posted March 20, 2011 (edited) Edit: Adam, stop hiding your proto ("A" to) "Z" under a bushel and post a build thread. Edited March 20, 2011 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
