Engine problems with my car
Parry_10
1- after a start the car sometimes the low oil level light stays on then flashes then goes off, checked the oil level its on maximum..
2- since i had my boost controller fitted and boost rasied to 1 bar and thje car dynoed it drives alot better but when its upto temperature it likes to idle at around 1300rpm- i sprayed brake cleaner on the hoses to try and find a vacuum leak but the revs didnt increase
Any ideas? Thanks
Chris
Guest Andy Bird
vacuum leak would have caused low idle and rich running would it not?
1. could be oil pump got getting it up to pressure, but dont know for sure, could be faulty oil pressure switch?
2. idle control valve?
