1st decat restrictor ring leak - odd idle?
BazzaAlpine
Hi all, Would a leaky seal at the 1bar restrictor ring cause the idle to not make up it's mind where to settle? Some times after a run it will be at 900RPM, sometimes 500RPM and various points in between. I reset the ecu yesterday as I was getting a missfire code (think it was 14) and not checked to see if the code came back yet.
