dani_r Posted March 18, 2011 Share Posted March 18, 2011 (edited) Who is doing these kits now? Is it a worthwhile purchase? *I mean Oil 'Filter' Relocation! Edited March 18, 2011 by dani_r (see edit history) Quote Link to comment Share on other sites More sharing options...
Wez Posted March 18, 2011 Share Posted March 18, 2011 Something else to go wrong, what the problem with the stock location? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 18, 2011 Share Posted March 18, 2011 I totally agree, 95% of the relocation installs I see look FAR more likely to have issues than the the stock set up. If you want a supplemental oil cooler leave the filter on the block, remove the Modine unit and have the COOLER take off plat directly under the filter. I have borrowed these photos from a members build log. Instead of the "cap" on the take off just screw the oil filter directly on. I would use an adaptor with a thermostat in it, which I stock. I do the same on Skyline engines. You need a custom adaptor for the block take off hole. Quote Link to comment Share on other sites More sharing options...
dani_r Posted March 18, 2011 Author Share Posted March 18, 2011 It's a bit of a nightmare getting to the filter and I'm worried about the sandwich plate adaptor for the oil pressure/temp senders leaking as they have done before! Without sounding totally stupid I did get a bit lost with what you meant there Chris! I'll just stick with the stock location for now. I will monitor my temps this year when BPU and consider a cooler. Quote Link to comment Share on other sites More sharing options...
David P Posted March 18, 2011 Share Posted March 18, 2011 (edited) This works well for me with an oil cooler mounted behind n.s. vent. A Supra oil filter relocation block converted to accept a Fram PH4854, using a bespoke M20-1.5 to 3/4"-16 bush. This upgrade fits snugly just above the fuel filter, and is nice and easy to get at for a 'clean' oil change. Plus 1 litre oil capacity. Extra oil cooling. Easier access. Hex head - 27mm. Available from local Motorfactor. If it were painted purple, maybe everybody would want one Edited March 18, 2011 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
Wez Posted March 18, 2011 Share Posted March 18, 2011 That's frigging huge Quote Link to comment Share on other sites More sharing options...
