rear brake disc size HELP
Dave
i want to order a set of discs but im faced with 2 options
2 x Rear Brake Disk 16" Wheel Model
Type: Vented
Position: Rear
Diameter: 307 mm
OR which is the right diameter for my n/a
2 x Rear Brake Discs
Type : Vented
Position : Rear
Diameter : 290
Thickness : 18.50
Bolt Holes : 5
These are sizes for the stock discs.
Smaller Brakes
Front - Calipers 2pot/Discs 296mm x 32mm
Rear - Calipers 1pot/Discs 307mm x 16mm
Larger Brakes
Front - Calipers 4pot/Discs 323mm x 30mm
Rear - Calipers 2pot/Discs 324 x 16mm
Smaller Brakes
Larger Brakes
nic i am assuming that i have the smaller size fitted to my car as its a j-spec .so what do the 290 mm fit then as there listed as mkiv supra rear discs http://www.importcarparts.co.uk/parts_info.asp?id=4596&cat=0&sub=0&sec=0&var=0&dc=&gen=&searchKey=rear%20brake%20discs
and these are the 307mm http://www.importcarparts.co.uk/parts_info.asp?id=677&cat=89&sub=1354&sec=0&var=0&dc=&gen=&searchKey=
Edited by Dave (see edit history)
