taking car to an mot station
barneybrendan
Mine is the same barn.
As far as im aware you can drive to and from an MOT without tax or an MOT. You have to have insurance however. Police will check with the MOT place if the pull you.
im not sure about the tax but you can definatly drive a car to and from an mot station without an mot
Same situation I was in Brendan. After a couple of calls to the police advice line they they stated it was okay to drive to and from the MOT station without tax. However it must be a pre-booked test and if failed, you must have the failure sheet as proof.
They said it was a must to bring all your documents with you just in case you do get pulled over. Also they said not to take the p*ss with the distance, it should be the one near to your home and you can only go direct to and from there.
