RyanSteel Posted March 16, 2011 Share Posted March 16, 2011 Hey guys, how are you doing? I'm from South Africa. Recently imported a MKIV '93 Supra. I am slightly confused with the following and wondered if any of you can help me? I am running an Advox Toms suspension kit. I have the following wheels: Front: 235/40/18 - 8J with a 35mm offset Rear: 265/35/18 - 10J with a 35mm offset I am wanting to repair the mags and fit new tyres, but the repair would cost slightly cheaper than just buying a decent set of 19" Lenso wheels here in South Africa. I have no body kit and arches are still standard. The big question? If I had to run 19" Rims all round, what is the biggest size tyre I can run with what offset? Without modifying my wheel arches. I was thinking of running a 30mm offset allround, but not sure about the tyre sizes? Any suggestions please? Thanks Link to comment Share on other sites More sharing options...
Luxluc Posted April 28, 2011 Share Posted April 28, 2011 How much does the suspension kit drop the car. I have adjustable coilovers, with Front : 235-35/19 (8.5J) Rear : 265-30/19 (9.5J) Offset : 35mm My (stock) rear arches needed a bit of work, as the wheels were slightly rubbing. Cheers Luc Link to comment Share on other sites More sharing options...
Nic Posted April 28, 2011 Share Posted April 28, 2011 What make/model are your current wheels, if the handling of the car is important to you I'd stick with 18's max rather than 19's. Lenso wheels are cheap for a reason - http://www.mkivsupra.net/vbb/showthread.php?241485-Cheap-and-nasty-wheels&highlight=weds I'd personally never trust a set of cheap quality wheels. Link to comment Share on other sites More sharing options...
