Nicolai Posted March 16, 2011 Share Posted March 16, 2011 Does somebody knows how much it wil costs to rebuilt the 2jzgte (uk) in the UK? Im looking at a high mileage one and thought better be safe than sorrow. Nicolai Link to comment Share on other sites More sharing options...
Scott Posted March 16, 2011 Share Posted March 16, 2011 With upgraded or standard parts? Upgraded around the 5k mark I think. Standard parts probably around the 3k mark at a guess. It all depends how far you want to take it really (Crank, Pistons, Valves, Head, bearings, etc etc) Best to get in touch with the various traders and see what they can do for you individually Link to comment Share on other sites More sharing options...
Nicolai Posted March 16, 2011 Author Share Posted March 16, 2011 Thanks Scott, It would just be standard parts as i want to be BPU max. I dont want to bother the traders as they are always busy. Is there a kit you can buy somewhere and do it yourself? Not me personally but a friend who is working for nissan (lol) Link to comment Share on other sites More sharing options...
Swampy442 Posted March 16, 2011 Share Posted March 16, 2011 You would have to measure everything before you bought bits, bearings, rings, pistons etc. And do bother traders, thats what they're there for Whats the mileage? Why does it need rebuilding? Stock engine is good for a fair few miles at BPU Link to comment Share on other sites More sharing options...
Nicolai Posted March 16, 2011 Author Share Posted March 16, 2011 Hi Swampy442, It has 200k+ miles, I will let him fully rebuilt the engine. (And i will look and learn) It doesnt need rebuilding yet, but i want to know what i can expect before i buy another one. Link to comment Share on other sites More sharing options...
Scott Posted March 16, 2011 Share Posted March 16, 2011 Thanks Scott, It would just be standard parts as i want to be BPU max. I dont want to bother the traders as they are always busy. Is there a kit you can buy somewhere and do it yourself? Not me personally but a friend who is working for nissan (lol) I don't have the numbers to hand (or most of the prices), and this is off the top of my head, but here goes.... Full Supra Gasket Kit £230 Pistons Piston Rings Rods Rod Bolts Rod/Caliper Pins Crankshaft Matched Big end Bearings for said crankshaft Head Studs Water Pump £135 Oil Pump £145 Pulley Wheel £260 Pulley Wheel Bolt £8 Timing Drive Gear Timing Drive Gear Key Timing Belt £37 Aux Belt £30 Valve Stem Seals Valves Springs Retainers Shims Buckets Of course this is assuming that the block itself is in fine fettle. If it isn't then you might be as well with a new block on top of that. Honing out the bores is one thing but you may need to look at oversized pistons etc if there is a lot of wear/damage. Without having the engine cracked open in front of you it is impossible to plan for a rebuild.... other than going the whole hog. Easiest option would be to have the car taken to a trader who will determin what is required and replace as necessary, in the UK this is fairly straight forward. Elsewhere will prove costly with regards to shipping etc and a LOT of time will be wasted IMO. Link to comment Share on other sites More sharing options...
jackso11 Posted March 16, 2011 Share Posted March 16, 2011 When i was in dubai recently I got taxis everywhere for a week, only 1 had less that 450k km on the clock! all toyotas. Japanese engines run forever. Link to comment Share on other sites More sharing options...
jackso11 Posted March 16, 2011 Share Posted March 16, 2011 scott, do you know how much a PAS pump is? new rather that refurbing Link to comment Share on other sites More sharing options...
Scott Posted March 16, 2011 Share Posted March 16, 2011 scott, do you know how much a PAS pump is? new rather that refurbing No idea mate, give MrT a call and ask for a discount once given a price. That's what I do Link to comment Share on other sites More sharing options...
Swampy442 Posted March 16, 2011 Share Posted March 16, 2011 Power steering pump is about 450 quid Adam. As Scott says Nicolai until the engine is in bits in front of you cant plan the rebuild. Why dont you run it until it fails then rebuild it? You might get another 100k miles out of it. There was a VVTI Aristo on ebay recently that had nearly 260k miles and was still going strong Link to comment Share on other sites More sharing options...
