Engine Oil .. Good buy or not?
Samsar
I wouldn't use it in my N/A judging by this info
2JZ-GE Engine Oil (NA (Non Turbo) Engine on a MKIV (JDM only))
Stock = 5w30 Semi Synthetic
I recommend Fully Synthetic 5w30-10w40
Dry Capacity 6.2L's
5w30 - Motul 300V
5w40 - Motul 300V, Silkolene Pro S
Change capacity 4.8-5.8L's
I'd recommened Silkolene Pro S 5w40.
Being less stressed that the GTE version any Fully Synthetic oil between a 5w30 and 10w40 should suffice.
Interval = 9-12,000miles depending on use
It'll be fine, but may knock MPG down about 0.002% :) I have run out of Neo gear oil that I put in some Hewland transaxles, and my Tractive box in the Skyline, I am dreading how much 4 litres of this is going to be.....
£102 for 3.785 litres, Jeez, that's gone up again. No wonder the Volvo has to make do with chip oil :)
https://shop.fluidsinmotorsport.co.uk/department/neo_synthetic_oils/?gclid=CIzUo5qz06cCFQoY4QodTRvv-Q
