overheating
kirvis
Today i'changed the thermostat because it as only blowing cold air. filled it up with the water, had i drive around, but nothing it was still blowing cold. then i went to work about 12 miles. and realized the temp gone up to red. came back home, put the old thermostat back in, but still the same. than i removed the thermostat, but it sill overheats!!! what can be the case?
could this be the water pump? but its not making any noises or anything
p.s. water hoses are rock hard and it seem only the top half of rad is hot and the bottom is just a bit worm
help please [sAD][/sAD]
  • Replies 51
Just found this off dnk if its an airlock
Let the car cool down, take the rad cap off and run the car with heater on full hot, keep running the car with the rad cap off whilst slowly topping up the system, you will lose some coolant out the rad cap, this is mostly the air escaping from the system, once the car is at its operating temp raise the revs to approx 2000 rpm still with the cap off, you will lose a little coolant so top it up as you go, this is the best way to shift an airlock in the system.
Keep checking the heater as when the air lock moves it'll blow hot then top up the rad and fit the cap, then re fill the expansion tank approx half full.
There is no need to drain any coolant you already have in there !!
I think its the water pump, the half hot/half cold rad is a bit of a clue. I had exactly the same thing on my brothers n/a Aristo, combination of the water pump and the thermostat
Trouble is when you get the dreaded airlock the pressure when it does start to cook prevents the water from circulating anyhow and then you do get the half/hot half cold. Not saying to rule out the waterpump as I too have had a couple of tussles with them in the past, but as it was running ok with just a cold heater before the change I would go with the airlock, in my experience they are bad for airlocks, although some time back I read a post from CW who said in his opinion the supra didnt suffer from them.
The hill method together with the gradual top up works for me everytime now though. Reckon your heater matrix is the most likely ause of blowing cold. Teres loads on here about that too, I had one that responded well to a blow throw with a hose pipe, all manner of crud got flushed through.
A big fat ass airlock will do the same thing though :)
I had this very same problem when I changed the coolant on my car. The temp would soar up, then gently come back down, then soar up. Sometimes it would stay hot, sometimes it would move up and down.
Half an hour on a hill had the problem sorted :D
Okay then thats good as it rules out the rad, follow my bleeding route and you should be fine unless there is another problem.
I'd fit a new o/e rad cap as this is a regular thing to go wrong.
It could be seized or blocked hence your hoses are pressurising, mine dont go rock hard
